Subwoofer making noises when receiver is off.
mossymonster
Hello, I have the PSW110 and it is hooked up to my Yamaha RX-V371 receiver. The issue is, that when I turn the sub on and play music, the sub makes a horrific sound that resembles thunder. It continues long after I turn off the receiver off and only stops when i unplug the power cord. Any suggestions or remedies are welcomed. Thank you.
How is the sub hooked up? Sounds like you've got an open ground/short somewhere. If you have it hooked up by speaker wire, then souble check your wires. If it's LFE (can't recall if the PSW110 has LFE RCA) - then it could be a short in the amp somewhere?65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
It is connected with an RCA, but I don't understand how less than three hours of use could cause this issue. I guess I'll have to wait until Monday to call Polk.
