Lip Sync Issue with New Sharp 80" TV
mufsoman
mufsoman Posts: 636
edited March 2013 in Electronics
Well, I pulled the trigger with the new Sharp LC-80LE632U, 80" TV. Got it wall mounted in the theater area and making tweaks in the picture settings. One issue I'm having is lip sync. I'm assuming the video single takes longer to go through the circuitry in a TV this size? So the sound is ahead of the video. I run all HDMI and the feed from the bluray player and satellite box goes through the SC07. Unfortunately, the SC07 does not have a lip sync adjustment and the Sharp TV doesn't either. It is pretty noticeable and distracting. Am I missing something? Anything I can do? Thanks
Sony 83A80L TV and Roku Ultra
Denon 3800
Parasound HCA-2205A
SVS Prime towers, center channel and bookshelfs (side surrounds)
Atmos: Mirage Nanosats x 4
Turbo MFW-15 x 2
Panasonic DP-UB820
APC H15
Morrow MA4 & AQ Cobra IC's, AQ Midnight speaker cables
Post edited by mufsoman on
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited December 2011
    I don't own a Pioneer AVR, but I was surprised to read that it didn't have a lip synch adjustment, so I googled "SC-07 lip synch". Evidently, it does have that feature. You should look it up, too. Do you have a manual?
  • Shicks18
    Shicks18 Posts: 397
    I had the same problem with my LG 55LW5600... I ran everything through receiver. What I did to fix the problem was run the cable box HDMI to the TV and run an optical cable from the TV's audio out into the receiver. There was no other way I could get the lips to sync. It works perfectly now.. best of luck.
    TV: LG 55LW5600
    Pre: Marantz SR6001
    Front Amp: Parasound HCA-1000A
    Center Amp: Marantz MA500
    Mains: Polk LSi9
    Center: Polk LSiC
    Sub: HSU VTF-3 MK-2
    Games: Xbox360 and PS3
  • Sherardp
    Sherardp Posts: 8,038
    See page 97 in your manual Pioneer calls it Auto delay, which is normally set to off. Try turning it on as it automatically corrects video to audio delay over HDMI. It may be what your looking for. The manual also states how to make manual adjustments found on page 96 under Delay. Congrats on the 80 incher though bro, what made you go screen over a projector? Just wondering your thoughts. Hope this helps you.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    Looks like a possible fix has been posted but while i'm here congrats on a sweet set.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • Drenis
    Drenis Posts: 2,871
    Seems common in Sharp sets. I have this with my Quattron. The Pioneer's have the delay option under the "Sound Options", not the Video options. I do find that this is not the case with EVERY channel.
    Also, this could be caused by the AVR converting the video internally unless this is disabled.
    Keep note, the Sharp sets (unless RECENTLY changed) do NOT put out anything more then stereo through the optical out. No DTS or anything. :(
  • mufsoman
    mufsoman Posts: 636
    I'll give the "Auto Delay" covered on page 97 a try this weekend. I missed that when I was searching the manual. Thanks for pointing this out.
    Sheradp - the reason I went with the 80" Sharp vs. projector is because I'm limited on wall space and ceiling height in my theater area. The largest screen I could use is probably no more than 90", and that would be pushing it. The 80" actuals fits nicely. Along with the fact that this a multi-purpose area, which a projector is not ideal for, the 80" LCD seemed to be the best solution to get as big as possible screen. I have 60 days to trial it and still be able to return it with no charge, so I figured why not. I'm not completely impressed with the picture quality, so I continue to play with the picture adjustments. Hopefully I can find a sweet spot without a professional calibration, so I can make a final decision. I know to make a set this big and sell it for reasonable amount of money, there were sacrficies made. Besides all this, I got a great price from BB. I made a low ball offer as I was walking away during negotiating figuring that would end it and instead they came within a couple bucks of meeting it. Maybe I should have gone even lower..... I'll post some pics this weekend.
    Thanks again for everyone's help. I'll provide an update
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • Drenis
    Drenis Posts: 2,871
    Took me a while to get the color I wanted from my Sharp set. How's the clouding on the new sets? Have they vastly improved? I got lucky with my 920 series set... The 810/820 series sets were the worst.
  • mufsoman
    mufsoman Posts: 636
    Drenis wrote: »
    I have not noticed any clouding. Of course now that you brought that up, I will have to look for it......
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • mantis
    mantis Posts: 17,385
    It's amazing your having this issue , I have not experienced this in probably 10 years. If everything is HDMI to the receiver and monitor out to the TV, I don't see how their can be an issue unless your cable signal is weak. I'd also look into having them come out and test your signal strength at your box.
    On a side not , how is that Sharp? 80 inch is just badass.
    Dan
  • polkatese
    polkatese Posts: 6,767
    With 80" size LCD at the current price level, I would imagine it will reverse the trend to go with projectors.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • Sherardp
    polkatese wrote: »
    Negative! If the room permits I would take the projector any day and go even larger. Even 92-96" of screen is huge. Imagine some of the screens we use here, 96-134" in full HD to add. Not to knock the OP in anyway just food for thought. If prices come down and I'm sure they will eventually, I can see a 110" LED on the wall. That too would qualify as bada$$.
    OP if your into calibration check out an EyeOne and read this
    http://www.curtpalme.com/forum/viewtopic.php?t=10457
    Should get that screen dead on in a matter of 20 minutes or so.
  • mufsoman
    mufsoman Posts: 636
    Attachment not found.I attached a few pics of the new TV.
    After doing some internet research, I found the recommendation to turn off the DNR, which I did, and the pic quality is much better IMO. Detail is better. It seems like with the DNR, there was too much blurring of detail unless the image was stationary.
    There is NO clouding that I can see in the screen.
    The black level is great, however, its almost too good. Blacks seem to blend together without alot of detail.
    Again, I would love to have an even bigger screen, but I just don't have the wall space. I can maybe go up to a 90", the screen would need to be off-center from the rest of the room and the lower edge would be border-line viewable from the back row without obstruction from the front row. This 80" fits perfect and seems to be a good solution.......
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • leroyjr1
    leroyjr1 Posts: 8,785
    That 80" seems like a perfect fit. Congrats!
    That looks awesome! Bigger? I agree, I wouldn't have the wall space either.
    Enjoy!
    cnh
  • Sherardp
    That looks really good OP. That room looks awesome ZIp tie that HDMI and power cable together from the display. Thumbs up.
  • mufsoman
    mufsoman Posts: 636
    Sherardp - I'm putting those cables behind the wall, just haven't gotten around to it yet. I had them tied together initially to clean it up until I got around to cutting holes in the wall, but there seemed to be some degredation of the picture quality when I did that, so I separated them again. Both cables are decent quality, but must not be shielded enough for side by side use. May be time for another Pepster power cord in the family.....
    I'm also planning on painting the ceiling flat black. Now that I've got that big screen, and its so close to the ceiling, there's quite a bit of light reflection off the current white ceiling. That project has been added to the Xmas vacation "To Do" list.
    Another plus I've found to this set up was in the center channel. The previous set up, which is still viewable in the System Showcase, had the center channel in a cubby hole of the cabinet. Even though the cubby hole was straight through without a back, between the that and the big RPTV, there was lots of reverb and echo. I had quite a few ceiling panels behind the setup to help absorb the sound, which I never totally accomplished. Now, with the Csi A6 out in the open, the center channel sound is definately improved. I have it angled up slightly now since its below ear level, but I think I'm going to build a riser for it to sit on so I can get it right. And yes, that another project for the Xmas vacation.
    BTW - still having lip sync problems. I found the Auto Delay in the SC07 menu and turned that on. Lip sync seems OK for signals from the Satellite, but still have issues with blurays. Very strange....
    Denon 3800
    Parasound HCA-2205A
    Turbo MFW-15 x 2
    Panasonic DP-UB820
    APC H15
  • Drenis
    Drenis Posts: 2,871
    Nice unit. Glad to hear of no clouding.
  • danz1906
    danz1906 Posts: 5,144
    Sweet System!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • mantis
    Damn Just when I thought my 60 inch was big. I feel a few inches :frown:
    Dan
  • leroyjr1
    ^^^^ 70"+ will be the norm in years to come. Everything's getting bigger. I remember back in the day when I
    thought my 36 inch tube TV was big.
  • Systems
    Systems Posts: 14,873
    That is a serious Mancave you have there!:cheesygrin:
    Awsome!
    I think the picture quality is killer just from the photographs, I can just imagine what it is like in person!
    So did you ever actually fix the lip sync problem?
    Testing
    Testing
    Testing
  • BlueFox
    BlueFox Posts: 15,251
    Is this the Elite version they just came out with?
  • leroyjr1
    BlueFox wrote: »
    70" is the biggest Elite.
  • ryanjoachim
    ryanjoachim Posts: 2,046
    That TV certainly is a beaut.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • Hendryn
    Hendryn Posts: 1
    edited March 2013
    Hello all,
    Just bought the sharp 60" smart tv. I hooked it up to my Polk audio sound bar and the audio is just barely ahead of the video. I've read a lot of things but can't seem to find the perfect fix for me. My soundboard is very basic with onli gain and channel adjustments.
    Any advice on how to get the tv and soundboard to sync up?
  • michael1947
    michael1947 Posts: 775
    edited March 2013
    That is a wonderful looking rig, congratulations. On lip sinc: just 2 nights ago I had a nasty almost 2 second sinc issue and after putting up with for several minutes I mentally retraced my steps of the preceding half hour or so. I remembered that I had used the fast forward, fast reverse, frame by frame back and forth about the time the lip sinc issue started. I just went fast forward for a few seconds and it was fixed. I was playing a blue ray...Transformers, and the remainder of the movie was without incident. Now...why at age 66 am I still watching movies about toys?:redface:
    Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
    Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's.
