Cleaning Vinyl?
disneyjoe7
disneyjoe7 Posts: 11,435
edited December 2011 in Electronics
What's some of our ideas in cleaning records?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
  • Fongolio
    Fongolio Posts: 3,516
    edited November 2011
    Nitty Gritty 2.5 FI with S3 and S9 tergitol mixed 400:1 with distilled water then rinse with distilled water and vacuum.
    SDA-1C (full mods)
    Carver TFM-55
    NAD 1130 Pre-amp
    The Clamp
    Nakamichi CR7 Cassette Deck
    Cambridge Audio DACmagic Plus
    ADC Soundshaper 3 EQ
    Ben's IC's
    Nitty Gritty 1.5FI RCM
  • gfong
    gfong Posts: 1,079
    Sink full of water with a dap of dish soap. Dip a paint brush in the water, go around the album a few times on both sides. Rinse and wipe off with soft cloth put in dish rack.
    Now, I only do this for used records that I get at the goodwill and used record stores. Takes the crap off them and cleans them up pretty good. Some people use distilled water, but since I only paid from 1 to 8 dollars for the record tap water works for me.
  • Joe08867
    Joe08867 Posts: 3,919
    I use the sink soap method mostly and the glue method sometimes depending on the degree of nastiness.
  • gdb
    gdb Posts: 6,012
    Are you the "handy" type ? If so, there's a bunch of DIY washers & vacuums that can be made on the "cheap". I could have built a machine but opted to buy the Spin Clean system instead. I still might slit a crevice tool, line it with the proper felt/velvet/etc. fabric so that I can vac the Spin Clean fluid off and then do a clear water rinse/vac after. There are several very long threads on vinyl cleaning on A. Karma. If you decide to do it in the sink, mind the labels, it's easy to get em soaked/ruined if you're not careful!
  • disneyjoe7
    I have to google some DIY stuff, like the wet sink thing. Seems to be the cleanest way to clean them, don't think anything is better then soap and water.
    On the other hand yes got some albums from Goodwill, any place I can get the inside sleeves? I missing some.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    Thanks Rick.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • wayne3burk
    wayne3burk Posts: 939
    i was just dollar bin diving at goodwill and some long haired guy there told me he uses Aleene's tacky glue....
    http://www.amazon.com/Aleenes-oz-Original-Tacky-Glue/dp/B00178KLEY
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • thsmith
    thsmith Posts: 6,082
    I use something similiar as this http://www.teresaudio.com/haven/cleaner/cleaner.html
    I have lab grade surfactant if you need some.
  • evhudsons
    evhudsons Posts: 1,175
    I haven't tried this buy seemed like something to try on cheapo vinyl:
    http://www.instructables.com/id/My-Incredible-Vinyl-Record-Block-and-Bar-Cleaner/
  • sda2mike
    sda2mike Posts: 3,131
    how do the labels hold up after being doused? do they trap moisture only to have it spin off at 33 and a third?
  • Joe08867
    Don't submerge the whole record. The Labels don't like to be doused.
  • disneyjoe7
    Did you use 2 of them one on each side?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • 2-tall
    2-tall Posts: 98
    The spin clean can be had for $79.00 and has done a very good job on my vinyl
  • evhudsons
    I think I'll get the spin clean for now for the wife for xmas, while I build a homemade one that vacuums.
  • indyhawg
    indyhawg Posts: 1,668
    A RCM is on my Christmas wish list.
  • gdb
    gdb Posts: 6,012
    I wish they'd hurry up with the development of nanobots, I think those little effers could do a fine job of cleaning LPs ! :)
  • disneyjoe7
    I cleaned my first LP tonight using the sink / soap / water / paint brush / micro cloth towel to dry. I happy to way it helped this LP sound which was really dirty before. I like to do a better cleaning job, but for now it's fine and cheap.
    Steve
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    Effective and cheap, didn't bother my back to much at all...... So all is good :razz:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    What is RCM?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • gdb
    gdb Posts: 6,012
    Record Cleaning Machine
  • gdb
    gdb Posts: 6,012
    Gasoline and a flaming match
  • disneyjoe7
    gdb wrote: »
    Ok that's me :cool:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • apc
    apc Posts: 779
    sda2mike wrote: »
    I bought one of these. It allows me to clean thoroughly without concern for the paper.
    link
    PS - I bought mine from William Sergent (wmsar@cox.net). Do not know current status.
    Husband, Father, Son, Brother, Friend.
  • markmarc
    markmarc Posts: 2,309
    For a budget/non-DIY solution the Spin Clean is worth the $80.
    Former Staff Member TONEAudio
    2 Ch. System
