Wanted: Polk SR5250 Crossover(s)
BeefJerky
BeefJerky Posts: 1,320
edited November 2011 in Wanted (WTB) Classifieds
I'm looking for one or two crossovers for the Polk SR5250 car speakers.
The pair I have now works, but one of them needed some work to get it going. I got a set used (for a steal), so I'm not complaining. As it was the pins for the -3db jumper were weak and broke when I tried to use them. For that I stole the ones from the +2db setting since I know I won't use that one. In addition, the tweeter cut in and out until I resoldered some cold joints. Looking at the board, I suspect that this crossover was exposed to the elements (probably mounted in the door panel) as it had some corrosion on the board. The other one works fine, but I haven't really opened it up to check it for corrosion either.
At any rate, since the crossover does work, I'm not desperate to replace it. However, since I do have a bit of "perfectionist" in me, it will bother me. If anyone has one (or both) in good condition let me know what you're asking.
Thanks!
Post edited by BeefJerky on
  • BeefJerky
    edited August 2011
    *BUMP*
    I know some people around here have gone active, so there must be someone with unused SR5250 crossovers. :)
  • BeefJerky
    edited September 2011
    Labor Day bump!
  • BeefJerky
    Yes, I did call. They are $150 each from Polk, which is more that I am prepared to pay, especially since I only paid $225 for the entire set. I am still hoping that someone will be kind enough to help me out here.
  • ipartywhenuhurt
    ipartywhenuhurt Posts: 130
    Looking for sr6500 or sr5250 for sale, im willing to buy the set
  • SNDM4N
    SNDM4N Posts: 2
    BeefJerky wrote: »
    Thanks!
    might be your lucky day, or not. i have a set of sr5250 that i'm will to split up. sell you the pair of xovers $200. let me know before i list it soon on ebay.
  • BeefJerky
    SNDM4N wrote: »
    At that price I'll pass. I only paid $230 for the complete set, and they don't regularly go for much more than that.
  • SNDM4N
    SNDM4N Posts: 2
    BeefJerky wrote: »
    how about i give you $230 for your set. just because you got it for that doesn't mean it goes for that. $150/each xover at polk. ballers can't be beggars...:arrowd:
    j/k
