Wanted: Polk SR5250 Crossover(s)
BeefJerky
I'm looking for one or two crossovers for the Polk SR5250 car speakers.
The pair I have now works, but one of them needed some work to get it going. I got a set used (for a steal), so I'm not complaining. As it was the pins for the -3db jumper were weak and broke when I tried to use them. For that I stole the ones from the +2db setting since I know I won't use that one. In addition, the tweeter cut in and out until I resoldered some cold joints. Looking at the board, I suspect that this crossover was exposed to the elements (probably mounted in the door panel) as it had some corrosion on the board. The other one works fine, but I haven't really opened it up to check it for corrosion either.
At any rate, since the crossover does work, I'm not desperate to replace it. However, since I do have a bit of "perfectionist" in me, it will bother me. If anyone has one (or both) in good condition let me know what you're asking.
Thanks!
Thanks!
Post edited by BeefJerky on
*BUMP*
I know some people around here have gone active, so there must be someone with unused SR5250 crossovers.
Labor Day bump!
Yes, I did call. They are $150 each from Polk, which is more that I am prepared to pay, especially since I only paid $225 for the entire set. I am still hoping that someone will be kind enough to help me out here.
Looking for sr6500 or sr5250 for sale, im willing to buy the set
Thanks!
might be your lucky day, or not. i have a set of sr5250 that i'm will to split up. sell you the pair of xovers $200. let me know before i list it soon on ebay. -
At that price I'll pass. I only paid $230 for the complete set, and they don't regularly go for much more than that.might be your lucky day, or not. i have a set of sr5250 that i'm will to split up. sell you the pair of xovers $200. let me know before i list it soon on ebay. -
how about i give you $230 for your set. just because you got it for that doesn't mean it goes for that. $150/each xover at polk. ballers can't be beggars...:arrowd:
j/k
