RTiA7 - Something is wrong with the high and mid range drivers
llflow
Have any one had any problem with their RTiA7 drivers? The sound has become harshed and distorted especially the mids and highs.
Post edited by llflow on
tried a different source yet?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Yes. Also using a different source with another set of speakers (sounded fine).
Pull the connector plates from the binding posts and replace them with wire. A lot of time those corrode and cause this issue.Main Surround -
What are you powering them with? How hard do you push them? What is your entire setup?AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Hard to offer help with the extremely limited information you provided.Political Correctness'.........defined
President of Club Polk -
AVR: Onkyo TX-NR708
Amplifier: Akai AM-73 (105 watts x 2)
Fronts: Polk RTiA7
Centre: Energy RC-Mini Centre
Rear: Energy RC-Mini
Sub: Energy ESW-C10
Speaker Cable: Monster XPHP
CD Player: Akai CD-73
I don't pushed the speakers extremely hard but sometime I would like to listen at slightly below "club" and "live orchestra" sound level. -
I had tried that with on difference. I also tried Bi-amp with the AVR and also sound the same.
AVR: Onkyo TX-NR708
Fronts: Polk RTiA7
Sub: Energy ESW-C10
CD Player: Akai CD-73 -
Have they always done this or did it just start happening?AVR: Onkyo Tx-NR808
Rear: FXI A4
Bi-Amping with an AVR is useless. No benefit. -
You can try to see if it is the tweeter/mids or the wooffer. You would also be able to see if it is both of the speakers or just one.Take the connector plates off and test the sound from the top posts (highs) and then the lower posts(woofer). Hook each one up individually to hear what is going on. Test both speakers individually as well.
When you do test them, ensure the amp and the avr are set with normal settings, not bi amped or anything like that. First I would test them with just the avr powering them and also unhook, other speakers ans sub if you have them.
If both are messing up I would look at what you have powering them. Goodluck. -
Only the Hid and Mid drivers sounded harsh and distorted especially female voice, cymbal, etc.
#14 reported
sounds like the tweeters are blown....PolkFest 2012, who's going>?
