RTiA7 - Something is wrong with the high and mid range drivers
llflow
llflow Posts: 6
edited December 2011 in Troubleshooting
Have any one had any problem with their RTiA7 drivers? The sound has become harshed and distorted especially the mids and highs.
Post edited by llflow on
  • nguyendot
    nguyendot Posts: 3,594
    edited November 2011
    tried a different source yet?
    Main Surround -
  • llflow
    llflow Posts: 6
    Yes. Also using a different source with another set of speakers (sounded fine).
  • nguyendot
    Pull the connector plates from the binding posts and replace them with wire. A lot of time those corrode and cause this issue.
    Main Surround -
  • jbooker82
    jbooker82 Posts: 1,627
    What are you powering them with? How hard do you push them? What is your entire setup?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    F1nut Posts: 52,009
    llflow wrote: »
    Hard to offer help with the extremely limited information you provided.
  • llflow
    llflow Posts: 6
    AVR: Onkyo TX-NR708
    Amplifier: Akai AM-73 (105 watts x 2)
    Fronts: Polk RTiA7
    Centre: Energy RC-Mini Centre
    Rear: Energy RC-Mini
    Sub: Energy ESW-C10
    Speaker Cable: Monster XPHP
    CD Player: Akai CD-73
    I don't pushed the speakers extremely hard but sometime I would like to listen at slightly below "club" and "live orchestra" sound level.
  • llflow
    llflow Posts: 6
    I had tried that with on difference. I also tried Bi-amp with the AVR and also sound the same.
  • llflow
    llflow Posts: 6
    AVR: Onkyo TX-NR708
    Fronts: Polk RTiA7
    Sub: Energy ESW-C10
  • jbooker82
    Have they always done this or did it just start happening?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Drenis
    Drenis Posts: 2,871
    llflow wrote: »
    Bi-Amping with an AVR is useless. No benefit.
  • gfong
    gfong Posts: 1,079
    You can try to see if it is the tweeter/mids or the wooffer. You would also be able to see if it is both of the speakers or just one.Take the connector plates off and test the sound from the top posts (highs) and then the lower posts(woofer). Hook each one up individually to hear what is going on. Test both speakers individually as well.
    When you do test them, ensure the amp and the avr are set with normal settings, not bi amped or anything like that. First I would test them with just the avr powering them and also unhook, other speakers ans sub if you have them.
    If both are messing up I would look at what you have powering them. Goodluck.
  • llflow
    llflow Posts: 6
    Only the Hid and Mid drivers sounded harsh and distorted especially female voice, cymbal, etc.
  • chumlie
    chumlie Posts: 8,658
  • danger boy
    danger boy Posts: 15,722
    sounds like the tweeters are blown....
    PolkFest 2012, who's going>?
