Good subwoofer for playing music only?
Neale13
Can someone tell me a good sub for under $700.00 dollars. I will only be playing music . thanks
Linn AV5140 fronts
Linn AV5120 Center
Linn AV5140 Rears
M&K MX-70 Sub for Music
Odyssey Mono-Blocs
SVS Ultra-13 Gloss Black:D -
can someone tell me the differnce is in sound between a sealed sub box and a ported one?
Rel t3 $399.99- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
also my room is large so i still should go with the sealed box not ported?
The most accurate subwoofer I have heard that does not break the bank and can fill up just about any size room is a VMPS Larger- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
If you are willing to go used my aci force 10 in sealed was the quickest most accurate sub I have ever owned (and I've owned a bunch). The second best was one of the old mirage bi polar subs (i had a bps-150i). The bi polar thing really does make for an incredibly fast and accurate sub. I've never owned maggies but i have read that those mirages are an excellent match.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Vr3MxStyler2k3 wrote: »Rel t3 $399.99
Where did you see this at that price? I cannot find it
Thanks,
EduardoHT:
POLK AUDIO RTI4 FRONTS
CSI3 CENTER
DEF TECH PROMONITOR800 SURROUNDS
PSW 125 SUB
PIONEER ELITE AVR23TXH AVR
APPLE TV 160GB
PANASONIC BLURAY PLAYER
50" PANASONIC PLASMA TCP50C2
2 CHANNEL:
KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
ROTEL RC 990BX PRE
ROTEL RB 990BX AMP
OPPO DV980 (AS CD PLAYER)
PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
MIT EXP2 SPEAKER CABLES -
I would recommend building your own. For 700 dollars you can build a very nice DIY sub if you don't mind putting in some effort and have the right tools.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
