Good subwoofer for playing music only?
Neale13
Neale13 Posts: 88
edited November 2011 in 2 Channel Audio
Can someone tell me a good sub for under $700.00 dollars. I will only be playing music . thanks
  • danz1906
    danz1906 Posts: 5,144
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Neale13
    Neale13 Posts: 88
    can someone tell me the differnce is in sound between a sealed sub box and a ported one?
    VR3 Posts: 29,748
    Rel t3 $399.99
  • Neale13
    Neale13 Posts: 88
    also my room is large so i still should go with the sealed box not ported?
    VR3 Posts: 29,748
    The most accurate subwoofer I have heard that does not break the bank and can fill up just about any size room is a VMPS Larger
  • rooftop59
    rooftop59 Posts: 8,120
    If you are willing to go used my aci force 10 in sealed was the quickest most accurate sub I have ever owned (and I've owned a bunch). The second best was one of the old mirage bi polar subs (i had a bps-150i). The bi polar thing really does make for an incredibly fast and accurate sub. I've never owned maggies but i have read that those mirages are an excellent match.
    Game Room 5.1.4:
    Bedroom 2.1
  • EDUBAG
    EDUBAG Posts: 403
    Rel t3 $399.99
    Where did you see this at that price? I cannot find it
    Thanks,
    Eduardo
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
    VR3 Posts: 29,748
  • Serendipity
    Serendipity Posts: 6,975
    I would recommend building your own. For 700 dollars you can build a very nice DIY sub if you don't mind putting in some effort and have the right tools.
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
