Little advice, please.
apc
apc Posts: 779
edited December 2011 in The Clubhouse
I've got a piece of vintage stereo equipment that my parents had when I was growing up. I've waffled back and forth about selling vs refurbishing the piece. IF I decided to sell, does anyone have a ballpark value? I had considered using it to stack my 2 channel stuff on, but there are too many pieces. I'd have a Belkin power supply, receiver, preamp, CD and TT. Starting to sound messy, right? What do y'all think about the attached console and it's potential use or value?
Husband, Father, Son, Brother, Friend.
Post edited by apc on
  • steveinaz
    steveinaz Posts: 19,545
    edited November 2011
    That thing is SWEET. I'd keep it. Put it in the mancave.
  • apc
    apc Posts: 779
    steveinaz wrote: »
    That's always been my intention; however, it needs some work. For instance, when volume is adjusted, static is present. Sounds like some Deoxit spray at it's simplest, but until I dive in I will not know. Time is precious as we remodel an older home. That's why I'm second-guessing this thing.
  • snow
    snow Posts: 4,358
    Is this a tube or SS console? If it is a SS console it isnt worth fixing and the value for selling it will be minimal $10-$20 bucks if your lucky.
    REGARDS SNOW
  • apc
    apc Posts: 779
    K, now something to consider. I don't know yet...having not popped the lid. It does have the warm tube-type sound, but until proven, I will reserve comment. Thanks!
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    Check the back, it's probably thin plywood held on by 6-8 screws. Take them out and look - if you see tubes it might be worth keeping. If you have room and it reminds you of good family memories, I'd find a place to keep it.
  • inspiredsports
    inspiredsports Posts: 5,502
    I think your console's cousin is sitting in my dad's house. It probably hasn't been powered up for 20 years and I believe it was a tube amped unit.
    I'll try to get over there to pull a model number off of it.
    They don't seem to sell for very much when I've seen them listed.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • maximillian
    maximillian Posts: 2,149
    My father has one too. He bought it in the mid-70's. Can't remember the brand. It's quadraphonic. Also has an 8 track in it. He uses it just as a piece of furniture. I think it still works. Not sure if SS or tubes.
  • snow
    snow Posts: 4,358
    If this console has happy memorys attached to it it is worth saving irregardless of whether it is tube or SS or if you simply like it as a piece of furniture. As far as the static while adjusting the volume is concerned most likely a good cleaning with deoxit on the various pots will most likely clear this issue up.
    REGARDS SNOW
  • apc
    apc Posts: 779
    Attachment not found.Ran across a couple of snaps including the model number. Now I can begin researching.
  • apc
    apc Posts: 779
    I thought the same thing. The plot thickens. See attachment from 1964. Seems SS, no tubes :(
  • apc
    apc Posts: 779
    deleted
  • apc
    apc Posts: 779
    We've moved and been remodeling. My stuff has been packed away in a corner for way too long. This weekend I got to some of it and put the old Magnavox to use. Whaddaya think?
  • chumlie
    chumlie Posts: 8,658
  • sda2mike
    sda2mike Posts: 3,131
  • apc
    apc Posts: 779
    sda2mike wrote: »
    2285?
    I wish, 2252B.
  • sda2mike
    nice setup...the '52 is a sweet beast
  • ken brydson
    ken brydson Posts: 8,990
    apc wrote: »
    I wish, 2252B.
    2252B is a nice receiver. Still have mine I bought new in my office rig.
  • apc
    apc Posts: 779
    What (if any) maintenance/repair have you had to do to your's? Had some lights replaced in mine, but have an annoying, albeit slight 'pop' when powered up that I know can't be good for the speakers.
  • ken brydson
    apc wrote: »
    I've got a light out that I've never fixed. Scratchy pots are the only things I've had to deal with
  • Drenis
    Drenis Posts: 2,871
    That Marantz is sweet. Looks identical to the one I owned when I was young (Around 15 years ago). It was a damn nice unit. I didnt know any better at the time when I owned it as to what a nice piece of equipment it was. My mother picking it up for $20 at a garage sale with a pair of speakers.
    I ended up unhooking a pair of speakers but forgot the unit was on and the wires touched...long story short, the left channel was crackly and shot. :(
  • ken brydson
    Here's mine...
  • ken brydson
    Here's mine...
    Odd, photo won't attach...
  • ken brydson
    Trying again
    Still didn't work. Oh well...
  • evhudsons
    evhudsons Posts: 1,175
    It's worth keeping even if nothing worked. It looks mancave worthy for sure.
    I googled it and there were several sites suggesting fixing them up for the mancave.
    http://www.retrothing.com/2008/09/furnishing-the.html
  • TECHNOKID
    TECHNOKID Posts: 4,298
    That is a nice piece of furniture (like they use to make in the old days) and worth keeping as is, also looks good with the remainder of your gear.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • apc
    apc Posts: 779
    evhudsons wrote: »
    Yep. This is me way down the page from September 20, 2010:
    Tony said...
    I have one that looks very close to this one and I know my parents bought it new in 1964 along with a house-full of other furniture. I was thinking of selling, but reading the above is making re-consider keeping it. Perhaps it is fate that drew me to this site. Thanks, because as someone said above, I will always think of my childhhod and parents when I use it.
    PS - Turning it on causes static sound. What do I do first to clean contacts or something?
