LsiF/X. Anyone got Pictures Comments
I ordered 2 pairs of fxiA4 but im thinking of selling a pair and getting the LsiF/X, hows the sound difference between the two?
Anyone got their own pics of the size of them, i google image it but I dont see a comparison i need.
Yamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub
Post edited by burts on
What comparison are you looking for? I could take a picture of them next to some LSi7's if that would help.
Comparison next to anything, like your hand, anything for a good visual size referance. Would these blow the fxia4 out of the water?Yamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub
What is the rest of your system composed of? What will you be powering them with? And why would you replace only one pair of FXi? Seems like a strange thought to me.Comparison next to anything, like your hand, anything for a good visual size referance. Would these blow the fxia4 out of the water? -
My new system of speakers gets here on wendsday powered by a yamaha a2000 and a emotiva 1000 watt xpa5
lsi15, lsic, two pairs of fxi a4 surrounds. If i had known i was buying the xpa5 I would have just ordered a pair of lsifx. I might and probably just keep my fxi a4s for surround and rear or run a pair of lsifx for my sides with a4 in the back. Mix match should be perfectly fine, i been running mixed match for 14 years fine, one pair of lsifx would complete a matched 5.1 if i deem the high price worth itYamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub -
See showcase.Shoot the jumper.....................BALLIN.............!!!!!
I would have just went with lsifx. Some people also prefer a traditional direct firing book shelf for the rear surrounds. I believe according to THX you only use bipole / dipole speakers for side surrounds, and a book shelf for rear surrounds.
Also cramming in a 7.1 system in a room that is to small isn't a good idea.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
I think it's less about room size, and more about proper positioning. I have a 7.1 system in a small room (10x11.5), but I have them positioned properly. There is a noticeable improvement in terms of the surround sound. Sound that is supposed to come from behind actually does, and it makes a (somewhat startling) difference in certain movies.I would have just went with lsifx. Some people also prefer a traditional direct firing book shelf for the rear surrounds. I believe according to THX you only use bipole / dipole speakers for side surrounds, and a book shelf for rear surrounds.
Also cramming in a 7.1 system in a room that is to small isn't a good idea. -
Here are few pics of mine. I replaced Def Tech Gem XL's so I can't really offer a comparison to what you have. Bob -
You'll be fine with the FXI's, you probably wouldn't hear a difference between the two.HT SYSTEM-
lsi 9's -
Thanks for the pics its exactly what i wanted to see. I figure im currently happy with my 7.1 in my small living room, so im a just run 7.1 again but add 2 sats for presence to 9.1. The more i shove my seat forward the more space behind me and the rear surrounds
I think tony might be rightYamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub -
Burts, those pictures are of the LSiM/FX's, not the LSi/FX's. I will try to get a couple of comparison pics of the LSiFX's up for you later tonight.
