LsiF/X. Anyone got Pictures Comments
burts
burts Posts: 33
edited November 2011 in Speakers
I ordered 2 pairs of fxiA4 but im thinking of selling a pair and getting the LsiF/X, hows the sound difference between the two?
Anyone got their own pics of the size of them, i google image it but I dont see a comparison i need.
Yamaha A2000/Emotiva Xpa5/Oppo 93/Polk Lsi15/Polk LsiC/Polk FxiA4 Surround/Polk FxiA4 Presence/Mtx Powered Sub
Post edited by burts on
  • BeefJerky
    BeefJerky Posts: 1,320
    What comparison are you looking for? I could take a picture of them next to some LSi7's if that would help.
  • burts
    burts Posts: 33
    Comparison next to anything, like your hand, anything for a good visual size referance. Would these blow the fxia4 out of the water?
  • mdaudioguy
    mdaudioguy Posts: 5,164
    burts wrote: »
    What is the rest of your system composed of? What will you be powering them with? And why would you replace only one pair of FXi? Seems like a strange thought to me.
  • burts
    burts Posts: 33
    My new system of speakers gets here on wendsday powered by a yamaha a2000 and a emotiva 1000 watt xpa5
    lsi15, lsic, two pairs of fxi a4 surrounds. If i had known i was buying the xpa5 I would have just ordered a pair of lsifx. I might and probably just keep my fxi a4s for surround and rear or run a pair of lsifx for my sides with a4 in the back. Mix match should be perfectly fine, i been running mixed match for 14 years fine, one pair of lsifx would complete a matched 5.1 if i deem the high price worth it
  • Sherardp
    Sherardp Posts: 8,038
    See showcase.
  • jbooker82
    jbooker82 Posts: 1,627
    I would have just went with lsifx. Some people also prefer a traditional direct firing book shelf for the rear surrounds. I believe according to THX you only use bipole / dipole speakers for side surrounds, and a book shelf for rear surrounds.
    Also cramming in a 7.1 system in a room that is to small isn't a good idea.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • BeefJerky
    jbooker82 wrote: »
    I think it's less about room size, and more about proper positioning. I have a 7.1 system in a small room (10x11.5), but I have them positioned properly. There is a noticeable improvement in terms of the surround sound. Sound that is supposed to come from behind actually does, and it makes a (somewhat startling) difference in certain movies.
  • bslep
    bslep Posts: 24
    burts wrote: »
    Here are few pics of mine. I replaced Def Tech Gem XL's so I can't really offer a comparison to what you have. Bob
    You'll be fine with the FXI's, you probably wouldn't hear a difference between the two.
  • burts
    burts Posts: 33
    Thanks for the pics its exactly what i wanted to see. I figure im currently happy with my 7.1 in my small living room, so im a just run 7.1 again but add 2 sats for presence to 9.1. The more i shove my seat forward the more space behind me and the rear surrounds
    I think tony might be right
  • BeefJerky
    Burts, those pictures are of the LSiM/FX's, not the LSi/FX's. I will try to get a couple of comparison pics of the LSiFX's up for you later tonight.
