Integrated amplifier.
lanchile
Hello fellas! this is my new integrated amplifier. I finished this morning at 4:30. Very happy with sound.it is quiet as a mouse no noise at all even at turn on or off. the offset is 1.7mv left channel and 1.8mv right channel.
Make it simple...Make it better!
Post edited by lanchile on
Man that looks pretty. What wattage you looking at?"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Thanks, it is 130 watts RMS. I spent in parts around $500.
This is some specifications:
Audiophile Mosfet, Dual symmetrical differential power amplifier
Direct Signal Purist Concept. it uses 2 pairs 2SK1058/J162
per channel produced by Renesas designed specifically for audio
application. Unlike conventional amplifier, it only require 2 stage
signal amplification to drive these mosfets, hence very natural sounding.
You can feel the drum sticks hitting the cymbals and the piano hammer
hitting the strings'
130watts RMS 8ohms
250watts RMS 4ohms
THD : 0.008% (20 Hz : 20 kHz, 8 ohms)
Frequency Response 4 Hz - 100 kHz
Damping Factor (20-20K Hz, 8 ohms) : 500
Signal to Noise Ratio : 120 dB 'A' weighted
Input Impedance/Sensitivity : 33K / 1V
Total dead silent at idle, absolutely no hiss or hum at full ear contact with tweeter and woofer at gain of 40X (32dB)
and an input Sensitivity of 1V for rated output of 130watts RMS 8ohms
Complete silence, No thump or noise during turn on/off . (No relay, Direct output)
it has two pairs of balanced input differential..This will ensure accurate imaging of every instrument
and vocals at complex and high energy passages.
Very high quality double sided PCB, gold plated solder pads. ISO certified
Output devices : genuine 2 pairs Renesas 2SK1058/J162
Low noise and low capacitance audio drivers/transistors throughout
Low ESR capacitors
High Quality sealed variable resistors
low noise audio resistorsMake it simple...Make it better! -
That is VERY slick
That is VERY slick
Yeah!!! I always wanted to build a good amp, but slick. This is my first time I build a slick amp all the others were standar size. it is slick but very heavy lol. 12L X 7w x 2 1/2 HMake it simple...Make it better! -
That's awesome that you built an amplifier , how would I get information on how to build my own amp ?
Just go to Diyaudio.com. I am a member there too! you will learn a lot and in not time you will build your own amp. even Nelson Pass is there, you can build his amps too. I do not build his amps because they are class A and I do not like class A amps.polkfarmboy wrote: »That's awesome that you built an amplifier , how would I get information on how to build my own amp ?
I have build 6 amps so far. you need to know the basic in electronics like: read an ohmmeter, know how to solder and read a schematic and fallow instructions. you will get all the help you need there to build your first diy amp.Make it simple...Make it better! -
Uh oh! :rolleyes:
Are you thinking what I'm thinking?
This could cascade from broken binding posts, closet doors and plasma screens to speakers on fire burning down an entire neighborhood. (or would that be barn?)VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
hahahahahahaha that is the hard way to learn. But it is very, very, very dangerous to play with high voltages, especially with a huge capacitance in power supply.Make it simple...Make it better!
Today was the last adjustments in my integrated amp. I was able to bring down the offset to steady 00.6mv in each channel.
so far I am very happy with sound. :razz:Make it simple...Make it better! -
inspiredsports wrote: »Are you thinking what I'm thinking?
Makeover? -
Nice work man!Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Thanks steveinaz! it took me sometime, but at the end it was all good.Nice work man!
I had to put heat sinks on the sides, now the amp runs way cooler than before and I can push it really hard without getting as hot as before.it sound wonderful. it was a big plus:idea:. I wanted to build it as small as I could but powerfull at the same time.Attachment not found.Make it simple...Make it better!
Very nice integrated amp sir! I just joined DIY, lots of cool things to do over there, but building an amp of your own is awesome......Cheers
Is there are right up, parts list, or schematic that you used to build this amp?
It looks really interesting, right at the level of amp I want to build. Thanks -
I am a member from Diyaudio.com for many years. I have build many integrated amps, even from Nelson Pass (class A). it feels really good to know that I can "CHOOSE" the quality in the parts I put in my amps. I have had so many good comercial amps like Bryston. The sound is awsome.
"These are some specifications on the amp"
Dual symmetrical differential power amplifier:
130watts RMS 8ohms
250watts RMS 4ohms
Very Low noise selected components throughtout.
Low ESR capacitors
Just join the diyaudio.com club! you will find a lot of schematics, kits etc,etc. you will meet Nelson Pass there too.
From the all known "Gainclones" to Nelson Pass class A amps!!!
you can build amps point to point, make your own boards or buy the boards already made.
You can get all the help you will ever need to build you OWN amp. Most of these diy amps can and will outperform commercial amps costing $2.000 USD and up!!!. Do not believe me?. Just go there and find out for yourself. is it difficult? not really! just need to know the "basic" in electronics like: how to read and use a multimeter, how to solder, fallow instructions on schematics, know electronic parts like: capacitors, resistors, inductors, diodes, transistors, transformer etc,etc... and all their functions. after this, you will NEVER buy a commercial amp anymore!!!. BUILD IT YOUR WAY.:idea:Make it simple...Make it better! -
well I was just wondering if you based your amplifier off of a specific design or if you just built it completely on your own.
Well, I build it using boards already made, but you can do it point to point too ( a lot of wires).you can pick a schematic of a design. Diyaudio has a lot of of them like: many from Nelson Pass, Krell clones, Gainclones, and many more.also you will find a lot of modifications and improvements in commercial amps.Make it simple...Make it better!
