Integrated amplifier.
lanchile
lanchile Posts: 560
edited December 2011 in DIY, Mods & Tweaks
Hello fellas! this is my new integrated amplifier. I finished this morning at 4:30. Very happy with sound.it is quiet as a mouse no noise at all even at turn on or off. the offset is 1.7mv left channel and 1.8mv right channel.:smile:
Make it simple...Make it better!
    EndersShadow Posts: 17,765
    edited November 2011
    Man that looks pretty. What wattage you looking at?
  • lanchile
    lanchile Posts: 560
    Thanks, it is 130 watts RMS. I spent in parts around $500.
    This is some specifications:
    Audiophile Mosfet, Dual symmetrical differential power amplifier
    Direct Signal Purist Concept. it uses 2 pairs 2SK1058/J162
    per channel produced by Renesas designed specifically for audio
    application. Unlike conventional amplifier, it only require 2 stage
    signal amplification to drive these mosfets, hence very natural sounding.
    You can feel the drum sticks hitting the cymbals and the piano hammer
    hitting the strings'
    130watts RMS 8ohms
    250watts RMS 4ohms
    THD : 0.008% (20 Hz : 20 kHz, 8 ohms)
    Frequency Response 4 Hz - 100 kHz
    Damping Factor (20-20K Hz, 8 ohms) : 500
    Signal to Noise Ratio : 120 dB 'A' weighted
    Input Impedance/Sensitivity : 33K / 1V
    Total dead silent at idle, absolutely no hiss or hum at full ear contact with tweeter and woofer at gain of 40X (32dB)
    and an input Sensitivity of 1V for rated output of 130watts RMS 8ohms
    Complete silence, No thump or noise during turn on/off . (No relay, Direct output)
    it has two pairs of balanced input differential..This will ensure accurate imaging of every instrument
    and vocals at complex and high energy passages.
    Very high quality double sided PCB, gold plated solder pads. ISO certified
    Output devices : genuine 2 pairs Renesas 2SK1058/J162
    Low noise and low capacitance audio drivers/transistors throughout
    Low ESR capacitors
    High Quality sealed variable resistors
    low noise audio resistors
  • Drenis
    Drenis Posts: 2,871
    That is VERY slick
  • lanchile
    lanchile Posts: 560
    Drenis wrote: »
    That is VERY slick
    Yeah!!! I always wanted to build a good amp, but slick. This is my first time I build a slick amp all the others were standar size. it is slick but very heavy lol. 12L X 7w x 2 1/2 H
  • polkfarmboy
    polkfarmboy Posts: 5,703
    That's awesome that you built an amplifier , how would I get information on how to build my own amp ?
  • lanchile
    lanchile Posts: 560
    Just go to Diyaudio.com. I am a member there too! you will learn a lot and in not time you will build your own amp. even Nelson Pass is there, you can build his amps too. I do not build his amps because they are class A and I do not like class A amps.
    I have build 6 amps so far. you need to know the basic in electronics like: read an ohmmeter, know how to solder and read a schematic and fallow instructions. you will get all the help you need there to build your first diy amp.
  • lanchile
    lanchile Posts: 560
    Keiko wrote: »
    Uh oh! :rolleyes:
    hahahahaha. come on!!! He can do it too... and you too!!!
  • zingo
    zingo Posts: 11,258
    Very good looking amp; very clean.
  • lanchile
    lanchile Posts: 560
    Thank you zingo!
  • inspiredsports
    inspiredsports Posts: 5,502
    Keiko wrote: »
    Uh oh! :rolleyes:
    Are you thinking what I'm thinking?
    This could cascade from broken binding posts, closet doors and plasma screens to speakers on fire burning down an entire neighborhood. (or would that be barn?)
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • lanchile
    lanchile Posts: 560
    hahahahahahaha that is the hard way to learn. But it is very, very, very dangerous to play with high voltages, especially with a huge capacitance in power supply.
  • lanchile
    lanchile Posts: 560
    Today was the last adjustments in my integrated amp. I was able to bring down the offset to steady 00.6mv in each channel.
    so far I am very happy with sound. :razz:
  • Drenis
    Drenis Posts: 2,871
    Makeover?
  • steveinaz
    steveinaz Posts: 19,547
    Nice work man!
  • lanchile
    lanchile Posts: 560
    steveinaz wrote: »
    Nice work man!
    Thanks steveinaz! it took me sometime, but at the end it was all good.:mrgreen:
  • lanchile
    lanchile Posts: 560
    I had to put heat sinks on the sides, now the amp runs way cooler than before and I can push it really hard without getting as hot as before.it sound wonderful. it was a big plus:idea:. I wanted to build it as small as I could but powerfull at the same time.Attachment not found.
  • Soverign
    Soverign Posts: 11
    Very nice integrated amp sir! I just joined DIY, lots of cool things to do over there, but building an amp of your own is awesome......Cheers
  • Buddyboy1
    Buddyboy1 Posts: 3
    Is there are right up, parts list, or schematic that you used to build this amp?
    It looks really interesting, right at the level of amp I want to build. Thanks
  • lanchile
    lanchile Posts: 560
    Soverign wrote: »
    I am a member from Diyaudio.com for many years. I have build many integrated amps, even from Nelson Pass (class A). it feels really good to know that I can "CHOOSE" the quality in the parts I put in my amps. I have had so many good comercial amps like Bryston. The sound is awsome.
    "These are some specifications on the amp"
    Dual symmetrical differential power amplifier:
    130watts RMS 8ohms
    250watts RMS 4ohms
    Very Low noise selected components throughtout.
    Low ESR capacitors
  • lanchile
    lanchile Posts: 560
    Buddyboy1 wrote: »
    Just join the diyaudio.com club! you will find a lot of schematics, kits etc,etc. you will meet Nelson Pass there too.
    From the all known "Gainclones" to Nelson Pass class A amps!!!
    you can build amps point to point, make your own boards or buy the boards already made.
    You can get all the help you will ever need to build you OWN amp. Most of these diy amps can and will outperform commercial amps costing $2.000 USD and up!!!. Do not believe me?. Just go there and find out for yourself. is it difficult? not really! just need to know the "basic" in electronics like: how to read and use a multimeter, how to solder, fallow instructions on schematics, know electronic parts like: capacitors, resistors, inductors, diodes, transistors, transformer etc,etc... and all their functions. after this, you will NEVER buy a commercial amp anymore!!!. BUILD IT YOUR WAY.:idea:
  • Buddyboy1
    Buddyboy1 Posts: 3
    well I was just wondering if you based your amplifier off of a specific design or if you just built it completely on your own.
  • lanchile
    lanchile Posts: 560
    Buddyboy1 wrote: »
    Well, I build it using boards already made, but you can do it point to point too ( a lot of wires).you can pick a schematic of a design. Diyaudio has a lot of of them like: many from Nelson Pass, Krell clones, Gainclones, and many more.also you will find a lot of modifications and improvements in commercial amps.
