Help! No sound coming from Tweeters
rromeo923
rromeo923 Posts: 1,513
edited November 2011 in Vintage Speakers
I installed Larrys Tweeter brackets today. All seemed good. Until I played some music and now no sound out of right speaker tweeters.
All wires seemed to be connected.
One thing I forgot to turn off amp while I did this (did I short something?)
Please help me troubleshoot.
Fyi- I am not technical at all so please keep any recommendations in laymen speak.
Thanks!!
I got static in my head
Post edited by rromeo923 on
  • rromeo923
    FYI- SDA 1C's w/dual crossover. All wires to tweeters seem to come from bottom crossover.
  • rebuy
    rebuy Posts: 694
    rromeo923 wrote: »
    Thanks!!
    Turn off equipment, switch tweeters and see if the dead one plays where the good one is.
    If not it might be blown, of course it could be in the crossover since you didn't disconnect power.
    You are very lucky you did not blow your amp.
  • gimpod
    gimpod Posts: 1,793
    Why do people do these thing's like this without turning everything off first. :rolleyes: You probably fried the tweeters get an Ohm meter and check the the tweeters I think they should read 7 - 8 Ohms if they read ok then you most likely popped something in the crossover maybe the polyswitch if your lucky.
  • rromeo923
    Tweeters all work when connected to left speaker. Must be in the crossover. Polyswitch?
  • rromeo923
    This was a case of drunk SDA listening. The amp was left on from last night. I didnt even ck to see if it was on or not because of course "I always turn it off after listening" So I went about my business and was done and then went to do a listening test and then noticed that the amp was left on from last night.
  • gimpod
    gimpod Posts: 1,793
    rromeo923 wrote: »
    If your lucky, you can jumper it (it's a little blue thingy) to see if that fix's it if not you may have blown a cap or resistor. If you could post a pic of the affected crossover that might help.
    rromeo923 wrote: »
    Yea I've heard that one before, Like the checks in the mail. JK Just busting your ball's we've ALL had brain farts at one time or another.
  • rromeo923
    I tested the tweeters with multimeter. All read 6.5 ohms.
    Visually the crossover looks fine. I will take a pic and post.
    This may be a good time to upgrade the caps and resistors.
  • drumminman
    drumminman Posts: 3,396
    rromeo923 wrote: »
    Definitely!
  • rromeo923
    Upgrade time it is!
  • thejck
    thejck Posts: 849
    maybe you already checked this but have you made sure your amp didnt blow one channel?
  • rromeo923
    Amp is fine!!
    Thank God!
