hey Doc,
trubluluc
trubluluc Posts: 2,067
I'm ready to go SVS, I've narrowed my choices down to:
1. PB1-ISD
2. 20-39PCi
I really like the look of the tube sub, but I like the ability to set something on top of the box sub. I will be getting a pair of which ever I choose.
Question is: Any reason why I shouldn't get one of each?
I would put the tube up front for spacial reasons, and the box in back, where it would be the base for some Orchids.
thanks,
-Luc
Post edited by trubluluc on
  • kberg
    kberg Posts: 974
    edited March 2004
    trubluluc,
    I'll let Doc and others chime in with their own suggestions/recommendations, but I'll say this much for now. Depending on your specific listening environment and personal taste, suffice it to say that if you're in the financial position to purchase two PB1-ISD's or 20-39 PCi's, then you may also want to consider a single PB2-Plus or PC-Ultra.
    Mains: polkaudio RTi70's (bi-wired)
    Center: polkaudio CSi40 (bi-wired)
    Surrounds: polkaudio FXi30's
    Rear Center: polkaudio CSi30
    Sub: SVS 20-39 PC+
    Receiver: ONKYO TX-SR600
    Display: JVC HD-56G786
    DVD Player: SONY DVP-CX985V
    DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
    Remote: Logitech Harmony H688
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited March 2004
    The two choices have similar tune points and extension. They could be mixed in a room with good results, but you might have some phase issues with front to back placement.
    Agree with Kev - if you be spending $1200, get a PB2+ or a PC-Ultra, or a PB2-ISD.
    SVS
  • trubluluc
    edited March 2004
    I guess I'm used to hearing where the sound is coming from with current subs.
    PSW 450's. When I added the second sub, it really made a difference in making the source of sound less distinguishable.
    If one sub could accomplish this, I may be willing to step it up.
    I don't have the room for a PB2 or PB2-plus, (28" deep).
    But I like the PB1-plus, I just wish it came in black. I wonder why they make the PB2-plus in black but not the PB1-plus.
    -Luc
  • gacole2000
    gacole2000 Posts: 255
    edited March 2004
    Try e-mailing them, perhaps they can do one for you in black. They have excellent CS.
    AVR: Yamaha RX-V661
    DVD: Yamaha DV-C6480
    BR: Samsung 1600
    Mains: Polk RT55 (bi-amped)
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Subs: SVS 20-39 PC+ 12.3 & DIY SVS 12.2
    Projector: Optoma HD70 w/ 106" Elite Screen
    Power: Panamax MAX 5100
    Remote: Harmony One
  • faster100
    faster100 Posts: 6,124
    edited March 2004
    I talked to SVS about the whole custom color thing, they explained the whole process and why's and why nots.. They won't do it, it costs them more to change colors in current models that do or do not come a certain color.. They may offer colors in some models and black in others at a later date but not now..
    The pb1 + is almost the same size as the pb2, so if the pb2 doesnt fit the pb1+ might not either.. However the smallest sub is the pb1-isd and its pretty compact somewhat.. Ive had it before and they come in black, tan, white, gray stone and gold.. they sound great and are a nice sub for the money and size.. I now have the pb2-isd and its double strenth pb1 but comes in black only.. The pb1+ does come in a black stain :)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • gacole2000
    edited March 2004
    Faster,
    I don't think it does come in a black stain, or perhaps they don't have it listed. I was suprised by this as well?
    Greg
    AVR: Yamaha RX-V661
    BR: Samsung 1600
    Center: CS300
    Sides: FX1000
    Rears: RT/FX
    Remote: Harmony One
  • Dr. Spec
    edited March 2004
    Black was dropped as a stain option. Too hard to get right and too few requests. A few black PB1+ and PB2U snuck out and will probably be rare collector's items years from now.
    SVS
