Polk SDA SRS
stuckin4low
Need amplifier suggestions !!! The H/K I was going to use is not a common ground. Really want something north of 500 watts per channel. Suggestions?
Post edited by stuckin4low on
I maybe off base here but I think in the sticky about into on the sda there is a cable you can build that will allow you to use the amp you have take a look.Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Legacy Audio Focus SE
Legacy Audio Silverscreen HD center
Polk F/X500i Rears
Parasound HCA-3500
Sunfire Grand Cinema
Behringer iNUKE NU6000DSP
Pair of CraigSUB SS-18.1 -
I thought I read that the cable would work on the later TL's but not the earlier SRS's.
That maybe the case I am not too sure I am sure one of the vets of the site will be along shortly that will be able to say one way or the other. As for a new amp what are you looking to spend?Absolute corruption empowers absolutely.
Lg 55LW5600 TV
Onkyo PR-SC 5508
Polk F/X500i Rears
Parasound HCA-3500
It doesn't have to be new but I don't wNt to spend more than $800.
You do need a common ground amp for the SRS's the AI-1 SDA cable will not work on the SRS's
Thanks Toolman. That's what I figured.
Watts are not the answer, peak to peak current (amps) is what you're looking for. That said, I've got no suggestions in your price range.Political Correctness'.........defined
President of Club Polk -
F1nut is correct as 500 WPC in a home audio amp will be hard to come by even somewhat above your budget. The speakers will handle the wattage and they do like lots of power, but you need to realize that 500 WPC is only 3dB louder than a 250WPC amp. There are alot of really stout amps in the 150-250WPC that would work great with your SDAs. Search for brands like Parasound, Acurus, Rotel, Adcom, Sunfire/Carver. These offerings will fit your budget and would drive your speakers nicely.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
I understand watts are not the entire answer but they do count. I want something that will have high current and dynamic headroom. Having said that, there are plenty of amps that will fit those specs on eBay. Just have to be patient to find it. I just need suggestions on which amps "pair" well with the SRS's.
Carver M1.0t Modded MkII opt 2
Below are details of the Carver mk IItm series M-1.0t (non-inverting model):
Rating
Stock
Mk II
opt 002
Power
8 ohms
200 watts <0.15% THD
400 watts <0.15% THD
460 watts <0.15% THD
4 ohms
450 watts <0.15% THD
510 watts <0.15% THD
At Clipping
8 ohms
350 watts
450 watts
500 watts
4 ohms
500 watts
520 watts
550 watts
Dynamic
8 ohms
550 watts
670 watts
700 watts
4 ohms
832 watts
940 watts
1000 watts
2 ohms
928 watts
1250 watts
1290 watts
I have 2 of them and love them with SDA's.Run about $700.
Watch ebay or get a standard M1.0t and have it modded.I am always changing things so if you don't find one i might move one of mine.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Here is your answer. Sunfire and SDA's are a match made in audio heaven. Those that have heard my 2.3TL's powered by a Sunfire were blown away by the combo. This particular model doubles down into 4 ohms for 600wpc. That will be plenty of poser for you to get the job done and thensome.
http://www.audiogon.com/cgi-bin/cls.pl?ampstran&1325088703&/Sunfire-300-Load-Invariant-steThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Such as?
Try Audiogon, there's a better selection of higher quality amps.Political Correctness'.........defined
If you can find a used Rotel RB-1090, that will put out more than 500 watts per channel into a 4 ohm load. Pricing on those is around $900-$1200 still though. The RB-1090 is a common ground design.
You really don't need a massive amp to drive the SDA-SRS, as the originals were fairly efficient. A used Rotel RB-1080 would be fine, as would a B&K 200.2, or many others in the same price range of $400-$700 used. The Rotel and B&K amps are high current and can output 350+ watts per channel into the SRS. I'd recommend a B&K amp if you are still using the original tweeters in the speakers. -
Awesome, thanks for the suggestions to everyone except F1nut. Keep'm coming.
stuckin4low wrote: »Awesome, thanks for the suggestions to everyone except F1nut. Keep'm coming.
You really are stuck in 4 low, aren't you. :rolleyes:Political Correctness'.........defined
I think I can I think I can!!!
Any one have experience with Adcom? I found an Adcom GFA-555ii that has been restored for a good price. Don't know if this is a common ground amp though.
The Adcom 555 series I & II are common ground. I have a 555 Mark II that run a pair of SDA's and it is a very enjoyable combo. The only non-common grounds that I am aware of from Adcom in that time frame are the 585 monoblocks.The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche
Ummm no!! The 585's yes but thats a give in considering they are monoblocks I do know the 565's the 5802 are not common ground as well, you can tie the negitive posts together and be safe with the amps above..
I am almost positve the 555's are not common ground.. -
I believe the original GFA 555s are common ground. I sure hope so bc thats what I use on my SDAs haha
I have heard that the Series II are not though, if thats what you meant Larry -
I run a Parasound HCA2200 that I picked up for 500 bucks and use it with my SRS's. Mates well and no issues driving them at all. F1Nut offered you advice and not sure your problem with it. Watts are not everything, so don't get hung up on the number of 500. Parasound amps are common ground as well, any of them is what I was told by Parasound themselves. The A21 is a great amp as well but will be out of your price range.
TOOLFORLIFEFAN wrote: »Ummm no!! The 585's yes but thats a give in considering they are monoblocks I do know the 565's the 5802 are not common ground as well, you can tie the negitive posts together and be safe with the amps above..
I agree that the later 5XXX series were not common ground, when they switched to MOFSET, but the 5X5 line are all common ground, with the exception of the mono blocks (565, 585).The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche -
The 585 isn't a monobloc amp. It's stereo. The 565 is monobloc.
I'm thinking both of them were subject to the capacitor problem.
Aragon 8008ST just closed on eBay for $521/free shipping. That and a five-dollar jumper strap for the negative terminals and you'd be set. (or a 4004 and no need for the ground strap.) -
No, Jesse offered a tactless, wet-blanket, truism, but no guidance, and then acted all hurt when stuckin' called him on it. Whereas you offered both a fact and advice... and I'm sure both were appreciated.I run a Parasound HCA2200 that I picked up for 500 bucks and use it with my SRS's. Mates well and no issues driving them at all. F1Nut offered you advice and not sure your problem with it. Watts are not everything, so don't get hung up on the number of 500. Parasound amps are common ground as well, any of them is what I was told by Parasound themselves. The A21 is a great amp as well but will be out of your price range.
si4l,
Many good choices mentioned.
My SRS's have been Carver powered one way or another most of their lives, including the latest incarnation, a 5-ch Sunfire Signature Cinema.
Bi-amping the SRS's with the tweets on the Sig's Current output and Voltage outs to the MW's is a wonderful match, but may be just out of your $ range. As suggested earlier, a bi-wired 2-ch Sunfire would be an option worth pursuing.
Other Carvers worth looking for include later M1.5t's (Serial # 4000 and higher) and M4.0t's. Only Carver to avoid is the M500(t) series... not common ground.
Good luck...More later,
Tour...
Vox Copuli
The original 555 was common ground all the later series I believe are not common ground so they are a no no.
I stand corrected, 585 was stereo. Need more coffee.The secret for harvesting from existence the greatest fruitfulness and greatest enjoyment is to live dangerously. - Nietzche -
LOL....still carrying a chip over the "**** bag" topic, eh Tour?Political Correctness'.........defined
Just because someone tells you something that you don't want to hear, it doesn't mean that they are wrong. F1 really knows his stuff. You would be foolish not to at least consider what he is saying...stuckin4low wrote: »Awesome, thanks for the suggestions to everyone except F1nut. Keep'm coming.Zu Soul Supreme
Coincident Frankenstein mkIII
Esoteric K-07 -
Still tone deaf in all ways, eh Jesse?More later,
Tour...
Vox Copuli
