2nd hand speakers and warrenty
If I pick up a pair of speakers 2nd hand and need to replace a driver will Polk honor the 5 yr warrenty, the model is only 3 yrs old. If they don't honor the warrenty do you think they will offer drivers at a discount?
Front
Polk RT800i (BI-wired)
Rear
Polk RT600i
Center
Polk CS400i (BI-wired)
Sub
SVS 25-31PCi (22Hz tuning port)... it's SubHuman
Receiver
YAMAHA RX-V1400
TV
Mitsubishi WT-46807 HDTV
HD receiver
T i V o HR10-250
Rear
Polk RT600i
Center
Sub
Receiver
YAMAHA RX-V1400
TV
HD receiver
T i V o HR10-250
Post edited by fgr41 on
you will at least get 10% for being a club member.
Thats a good question though... I'd call Polk and ask, ca't hurt anyway.
HBomb***WAREMTAE*** -
HBomb
It's 20% and free 2 day shipping. Pretty good deal -
cool its been a while so thanks for making it that much better to be a polky;)
I have a great memory but its real short:p
Just make sure you tell them up front that you're a club member. We recently had some knucklehead pissing and moaning that he didn't get the discount. Polk CS is good but the're not mind readers
Directly from Polk's Limited Warranty:
POLK AUDIO LIMITED WARRANTY
Polk Audio, Inc. warrants to the original purchaser
only that this Polk Audio Loudspeaker
Product (the Product) will be free from
defects in materials and workmanship for
a period of five (5) years from the date of
original retail purchase from a Polk Audio
Authorized Dealer. However, this Warranty
will automatically terminate prior to the
expiration of the five (5) years if the original
retail purchaser sells or otherwise transfers
the Product to any other party."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
Well, there you have it! I guess 20% is better than nothing.Front
Rear
Polk RT600i
Center
Sub
Receiver
YAMAHA RX-V1400
TV
HD receiver
T i V o HR10-250
