banana plugs do not insert.
leftwinger57
leftwinger57 Posts: 2,917
This might have been covered in another thread but I cannot find it.My problem is that I have multiple devices that accept banan/plugs but it seems that length does matter here. With my Yamaha RX V-665 I insert these universal bananas and they go all the way in and it seems to be a tight fit ,now with my Adcom gfa555 the same plugs only go in half way.There does not seem to be any ill effects to this fit but alot of the shaft is still visible.On both units I've tried it w/ the posts tight all the way or loose all the way and it has no bearing on sound reproduction. Has any one else had this dual ill fitting plugs and what was your remedy for this .Again right now it plays fine and I'm getting full stereo.
  • halo71
    halo71 Posts: 4,637
    edited October 2011
    I don't think I have ever ran across that problem before. But whatever the hell you do. Don't take any of PFB's recommendations! phewwww......I still laugh when I think about seeing that picture he posted.
    --Gary--
    nooshinjohn Posts: 25,939
    edited October 2011
    PFB has the answers for this. Maybe he will chime in.
  • WilliamM2
    WilliamM2 Posts: 4,808
    edited October 2011
    I have some speakers where the banana plug does not go all the way into the post, and also A Marantz amp. There's only an 1/8" inch or so exposed, never been of any concern to me.
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    PM polkfarmboy for the answer :cheesygrin:
    just kidding
  • djperez81
    djperez81 Posts: 388
    edited October 2011
    I don't think PFB is gonna ever here the end of it...lmao
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • jchouston
    jchouston Posts: 122
    edited October 2011
    What did pfb do?
  • evhudsons
    evhudsons Posts: 1,175
    edited October 2011
    Whatever it is, it's not Polk Audio recommended. History of unfortunate but hilarious mishaps.
  • decal
    decal Posts: 3,205
    edited October 2011
    evhudsons wrote: »
    Mishaps...... That's putting it lightly!!!!!
  • mantis
    mantis Posts: 17,535
    edited October 2011
    Some banana binding posts are not as deep as others , when it stops going in your done. Don't try to force it anymore. Your surface contact on those binding posts is smaller.
    Dan
