banana plugs do not insert.
leftwinger57
This might have been covered in another thread but I cannot find it.My problem is that I have multiple devices that accept banan/plugs but it seems that length does matter here. With my Yamaha RX V-665 I insert these universal bananas and they go all the way in and it seems to be a tight fit ,now with my Adcom gfa555 the same plugs only go in half way.There does not seem to be any ill effects to this fit but alot of the shaft is still visible.On both units I've tried it w/ the posts tight all the way or loose all the way and it has no bearing on sound reproduction. Has any one else had this dual ill fitting plugs and what was your remedy for this .Again right now it plays fine and I'm getting full stereo.
I don't think I have ever ran across that problem before. But whatever the hell you do. Don't take any of PFB's recommendations! phewwww......I still laugh when I think about seeing that picture he posted.--Gary--
PFB has the answers for this. Maybe he will chime in.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I have some speakers where the banana plug does not go all the way into the post, and also A Marantz amp. There's only an 1/8" inch or so exposed, never been of any concern to me.
PM polkfarmboy for the answer :cheesygrin:
just kidding -
I don't think PFB is gonna ever here the end of it...lmaoMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
What did pfb do?
Whatever it is, it's not Polk Audio recommended. History of unfortunate but hilarious mishaps.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe
Mishaps...... That's putting it lightly!!!!!If you can't hear a difference, don't waste your money. -
Some banana binding posts are not as deep as others , when it stops going in your done. Don't try to force it anymore. Your surface contact on those binding posts is smaller.Dan
