Hooking up 2 center channels???
mole'
mole' Posts: 3,160
i just got my whole LSi system not too long ago. well i just picked up another LSiC at a great price and wanted to add it to my current setup. LSi15, LSiFX and LSiC. running the LSiC off of the ext amp. now my ? is will it be ok if i run the second LSiC off of the center channel speakers off of the AVR??? im guessing they will sound a lil different because of the power to each of them.
mole'
Post edited by mole' on
    nooshinjohn Posts: 25,922
    edited October 2011
    Do you have the Sunfire set up yet? If you do, the Sunfire has two outputs on the back. Just run them both off the Sunfire.
  • mole'
    mole' Posts: 3,160
    edited October 2011
    i dont have a sunfire amp. i have a Cinenova Grande 5 and a XPA-3. might just pick up a upa-1 for the center and get a splitter for the preout off of the AVR
    mole'
    EndersShadow Posts: 17,704
    edited October 2011
    So you mean connect one set of speakers to the Voltage Source and another to the Current Source correct? I only ask as this was something I might do when I finally get one of them there sunfire amps :smile:
  • rebuy
    rebuy Posts: 695
    edited October 2011
    I run 2 centers off an Onkyo and have had zero problems.
  • mole'
    mole' Posts: 3,160
    edited October 2011
    rebuy wrote: »
    how do you have them hooked up?
    mole'
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited October 2011
    You can use a biwire cable but I would advise against it with your lsic .One easy way would be running one of the receiver and the other of the amp and let the eq system sort them out
  • rebuy
    rebuy Posts: 695
    edited October 2011
    Connect the first center as you normally would, then run the pos from the first center to the pos of the second center, repeat for negative side wiring. done.
    My speakers are 8 ohm, RTI4's. You have 4 ohms centers and that might be a problem if you try to turn it up too loud and your current set up cannot handle the low ohm load.
    Hope this helps
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    Wouldnt that cause a major mis match in voice sound since one is designed to sound like a solid state amp and the other is supose to sound like a tube amp?
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    edited October 2011
    jbooker82 wrote: »
    I have no idea, hence asking for clarification.
    As I also have debated dual LSiC's OR LSi 7's for my fronts I want to make sure I understand how they are connected to one of the Sunfires.
  • jbooker82
    edited October 2011
    I dont have any experiance with the sunfires but that is just what I have read. You use one if you want a natural / neutral solid state sound, or the other if you want a warm tube amp sound.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • mole'
    mole' Posts: 3,160
    edited October 2011
    this is pretty much how i was gonna run them. one hooked up directly to the AVR and the other one hooked up to the Amp.
    rebuy wrote: »
    Hope this helps
    im not understanding how your saying to hook them up. do you mean in series? would that not lower the ohms the amp is seeing then????
    jbooker82 wrote: »
    im gonna try it tonight and find out....
    i was looking at a set of LSi7 for the center aswell, but i had already picked up my LSiC with the LSi15/LSiFX....and i got a killer deal on another LSiC that i could not pass up. so if it does not work out ill just sell the extra LSiC or make a LSi setup for my bedroom over my current RTi/RTia setup.....
    mole'
  • rebuy
    rebuy Posts: 695
    edited October 2011
    No, not running them in series, I'm running in parallel, this presents a 4 ohm load for my center. If I ran them in series it would be 16 ohms. Of course my Onkyo is not 4 ohm certified, but I have not ran into any problems since I hooked them up.
    I think running 2 LSIc in parallel would show as a 2 ohm load to your equipment.
  • mole'
    mole' Posts: 3,160
    edited October 2011
    rebuy wrote: »
    no, not running them in series, i'm running in parallel, this presents a 4 ohm load for my center. If i ran them in series it would be 16 ohms. Of course my onkyo is not 4 ohm certified, but i have not ran into any problems since i hooked them up.
    I think running 2 lsic in parallel would show as a 2 ohm load to your equipment.
    oic.......
    mole'
  • mole'
    mole' Posts: 3,160
    edited October 2011
    ok, its done.....
    have 1 LSiC hooked up to the Amp and the other hooked up to my SC-35. i can tell the difference FOR THE BETTER!!!! when listening to each center i can easily tell them apart from one another..... im gonna leave both of them in my setup.
    mole'
    edited October 2011
    mole' wrote: »
    Wouldnt you want them both to blend together so you could tell?
  • jbooker82
    edited October 2011
    That is kind of what I was thinking as well.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • mole'
    mole' Posts: 3,160
    edited October 2011
    i meant to volume. the one hooked up to the amp seemed louder
    mole'
    edited October 2011
    mole' wrote: »
    Do you plan to offset that, and if so how?
  • mole'
    mole' Posts: 3,160
    edited October 2011
    right now i have one on the audio rack right below the TV and the second one on the bottom of the rack facing upwards. i like it so far.
    mole'
  • codyc1ark
    codyc1ark Posts: 2,538
    edited October 2011
    mole' wrote: »
    I've seen one above the TV and one below it, I think this would be ideal, you'll need to make some sort of angled contraption that mounts to your wall, and use the keyhole slots on the back of the center to point to where you sit. vMAXSTYLEZERRRRZ3333 does it I believe.
    edited October 2011
    mole' wrote: »
    I meant the differences in the volume. I assume you would want them both to have the same SPL....
  • mole'
    mole' Posts: 3,160
    edited October 2011
    codyc1ark wrote: »
    i was thinking about that last night......
    mole'
