Auto on PSW 300 sub
Having trouble with my PSW 300 sub. It stays on all the time! At first I thought it was getting some sort of signal from my receiver (sony strd-1000es) even if the receiver was off. But If I unplug it at the sub input it will shut down in about 5 min. If I leave it plugged in at the sub input and unplug it from the receiver it just stays on. How do I have this repaired. Is there a part I can replace myself.
Ray E.
Ray E.
Post edited by Ray on
so it is my opinion that you should contact support or your dealer and have it repaired which in most instaces it will be replaced with a brand new amp.
Thanks, I appreciate the help.
