Csi A4 and Rti A7
tommyt21
tommyt21 Posts: 685
edited September 2011 in Speakers
I ran into space limitations so I am going to order a csi A4 for $192. I hope this will be a signifigant upgrade over my CS10. I have the Pio-SC-35 being delivered tommorrow. I am looking to get the RTi A7's ASAP but most all of the places that had them near $400 a pop are sold out. My fault for waitinig. If anyone knows of any good place to look for the A7's please let me know.
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Post edited by tommyt21 on
    EndersShadow Posts: 17,722
    Personally just get the RTi8's which are the older verision of the A7's. They will work fine and will have no timbre match issues. Plus its 400 FOR THE PAIR. Or get a set of RTi12's for 600 (Black) OR 800 (Cherry). These would be equivalent to the A9's.
    I think if you call them to order them you might even get the Club Polk discount on em.
  • tommyt21
    tommyt21 Posts: 685
    Personally just get the RTi8's which are the older verision of the A7's. They will work fine and will have no timbre match issues. Plus its 400 FOR THE PAIR: http://www.ebay.com/itm/PAIR-RTi8-CHERRY-Towers-Polk-Audio-GREAT-DEAL-/230635138999?pt=Speakers_Subwoofers&hash=item35b2ecefb7
    I have the PSW 505 how well will the 8's do in 2ch music? I will only do the music for parties but i still would like the wow factor
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    tommyt21 wrote: »
    See my edited post above......
    Then read this:
    The 8's will do everything the A7's would do. They do decent in 2 channel (better w/ a sub). The RTi 12's would really do well on that AVR and you may not feel the need for the sub unless your a bass head. I personally cant comment as I have the LSi15's in my setup.
  • tommyt21
    tommyt21 Posts: 685
    Then read this:
    I originally wanted the lsi15's and 6th ave has them cheap! $549 a piece however I ran out of space. If i got them the side woofer on both would be firing two inches from the wall.
    I may go with the a5's if iget impatient or suck it up and pay retail
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
    tommyt21 wrote: »
    I would highly suggest getting the 15's despite not having space right now. They will only get more expensive since they are now discontinued. It wont hurt them to fire into the wall like that. Might actually help with their bass response (since you normally put a sub in the corner to get more gain anyway).
    Then get the db840 car sub from Crutchfield when they have a buy one get one 1/2 off sale to replace the stock 8" woofer.
  • tommyt21
    tommyt21 Posts: 685
    Dang it dude! I need to go home and drink a beer now! I might just hold on the csi a4 and take a harder look at the lsi15.. AHHHHHHH. Back to the drawing board. PS will the sc-35 power the lsi okay?
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • PrazVT
    PrazVT Posts: 1,607
    FYI I think the RTi10s are the older version of the A7s, not the RTi8s. If you're still going in that direction, the polk direct store has:
    RTi12s (RTi A9) for $600 (black) and $800 (cherry) per pair and Black RTi A7s for $700 for the pair.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    tommyt21 wrote: »
    Yup, its got ICE power. I know of a couple fella's on this board running LSi's w/ the SC-35 and SC-37 with no problems. Plus with pre-outs if you felt the need to get a dedicated amp later on, you could.
  • PrazVT
    PrazVT Posts: 1,607
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
  • EDUBAG
    EDUBAG Posts: 403
    see my edited post above......
    Then read this:
    The 8's will do everything the a7's would do. They do decent in 2 channel (better w/ a sub). The rti 12's would really do well on that avr and you may not feel the need for the sub unless your a bass head. I personally cant comment as i have the lsi15's in my setup.
    let me clarify that the rti8 is not the predecessor to the rtia7 but to the rtia5. The rti10 would be the predecessor to the rtia7.
    HT:
    POLK AUDIO RTI4 FRONTS
    CSI3 CENTER
    DEF TECH PROMONITOR800 SURROUNDS
    PSW 125 SUB
    PIONEER ELITE AVR23TXH AVR
    APPLE TV 160GB
    PANASONIC BLURAY PLAYER
    50" PANASONIC PLASMA TCP50C2
    2 CHANNEL:
    KEF R300 THREE WAY BOOKSHELF GLOSS PIANO BLACK
    ROTEL RC 990BX PRE
    ROTEL RB 990BX AMP
    OPPO DV980 (AS CD PLAYER)
    PIONEER PL100 TURNTABLE WITH SHURE MX97E CART
    MIT EXP2 SPEAKER CABLES
  • mole'
    mole' Posts: 3,160
    i have a set of RTi10 and LSi15. the LSi15 is not much bigger than the RTi10. the RTi10 has more balls/bass to it but the sound is sooooooo clear on the LSi15. i swear im hearing things i have never heard before in songs with them. 150% happy with them so far.
    mole'
    mole' wrote: »
    Have you modded the sub yet? If not add 25% more for a total of 175% :smile:
  • mole'
    mole' Posts: 3,160
    not yet....i placed the order for the db840 and mm840. wanted to try them both out and see how it goes.......then im gonna have the x overs on the LSi15/LSiC modded..... so at that point i should be at the 200% mark.
    btw i only have a few days of burn in/break in on the whole LSi system. so im thinking the sound will get better
    mole'
