hooking psw505 sub to a 2 channel reciever
acdoctor
I have a pioneer sx1980 receiver and am purchasing the polk psw505 sub. The wiring diagrams do not have a method for hook up to my 2 channel receiver and I do not want to damage it with an improper wiring configuration or an non compatible sub woofer. Need wiring instructions please. have A,B,C speaker out puts and I can select any combination of 2. Can I just use my B to the sub in and A to my speakers or do I have to use just A to sub and sub to speakers?
Post edited by acdoctor on
Hello,
Welcome to Polk's forum! A good connection method would be to run a right and left speaker wire from the receiver's B speaker connection to the corresponding right and left speaker level input connections on the PSW505. Then activate "A+B" from the receiver's front panel.
Regards, Ken
