hooking psw505 sub to a 2 channel reciever
acdoctor
acdoctor Posts: 1
edited September 2011 in 2 Channel Audio
I have a pioneer sx1980 receiver and am purchasing the polk psw505 sub. The wiring diagrams do not have a method for hook up to my 2 channel receiver and I do not want to damage it with an improper wiring configuration or an non compatible sub woofer. Need wiring instructions please. have A,B,C speaker out puts and I can select any combination of 2. Can I just use my B to the sub in and A to my speakers or do I have to use just A to sub and sub to speakers?
Post edited by acdoctor on
  • [Deleted User]
    [Deleted User] Posts: 7,598
    Hello,
    Welcome to Polk's forum! A good connection method would be to run a right and left speaker wire from the receiver's B speaker connection to the corresponding right and left speaker level input connections on the PSW505. Then activate "A+B" from the receiver's front panel.
    Regards, Ken
