"The System"
VR3
I think I have finally ironed out my system - once my subs are done for my 2 channel it will be complete...
Everyone told me I was crazy but I have had the same amps and preamp for 4 years, the CDP for 2 years and the speakers for 2 years...
Loving it still and only gets better!
Post edited by VR3 on
What's up with the shelf of crossovers & drivers?
Eh - Just did not have anywhere else to put them to be honest and really just had nothing to put on the shelf! haha
I have no dvd or blu ray player and I got rid of my cable since I never watched TV (literally had not watched in almost a year and a half) so yep - deemed it the crossover/driver shelf...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I like the orange wall paint. Where can I buy some orange paint? :biggrin:
Looks good, Trey.
Home Depot sells orange paint. Lowes sells blue. I think that's the way it works. -
home depot sells orange paint. Lowes sells blue. I think that's the way it works.
lol!Dan
I know its just supposed to be just about the music, but ..... I like that shelf with the guts on it. :redface:
Nice gear.
Instead of orange walls, I'd suggest black, if it is still available. Somewhere.Sal Palooza -
mrbigbluelight wrote: »...
I know Menard's has green, that might work too. I bet Ace Hardware has black. -
I like it!Vr3MxStyler2k3 wrote: »Eh - Just did not have anywhere else to put them to be honest and really just had nothing to put on the shelf! haha
I have no dvd or blu ray player and I got rid of my cable since I never watched TV (literally had not watched in almost a year and a half) so yep - deemed it the crossover/driver shelf..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Very nice, especially the Odyssey stuff. I'm a big fan. Kismet monoblocks - impressive!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
Thanks guys!
The orange is actually not what the pictures depicts - the orange is much darker in normal light and the lighting in the room is real even (but low light) with 4 equally spaced 40 watt bulbs in the room...
Thanks for the compliments!
I really like the Odyssey and Tyler sound - they work together this is for sure.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Looks awesome Trey & would love to hear it.
I couldn't tell from the pics if you are still tilting your speakers back using a cd case? -
Thanks! You are welcome anytime.
Not anymore - the Super Tower's tweeters are about 4"+ higher than my 7u's tweeter so it achieves about the same results without tilt.
I use to tilt them and realized after a bit it threw everything off because of how tall they are...
Will note any of the shorter Tyler speakers sound much better with tilt... imo- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Looks great man!!Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
Thanks guys!!
Appreciate the compliments!- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
It does look great, and I like the color on the walls!
Looking good. But I have to ask what's the TV used for?
I have a laptop that I use at my DVDP, BRP - XBOX 360
