SDA's on CL in Texarkana, TX -- what are they worth?
quezwood
Just curious. I have been looking at SDA's for awhile and these are not too far away.
http://dallas.craigslist.org/dal/ele/2595613750.html
Super Stereo Speakers - $850 (Texarkana, Tex)
Date: 2011-09-15, 2:35PM CDT
Reply to: sale-cdbka-2595613750@craigslist.org [Errors when replying to ads?]
Polk Audio SDA Signature stereo speaker system. Concert quality in your home if you can handle it!
Cost about $3000.00 new in 1985. These two units still in exceptionally good condition.
Driver Complement Subwoofer 1 - 15" Diameter (38.10cm)
Sub-bass radiator Midrange 8 - 6-1/2" Diameter (16.51cm)
Trilaminate-polymer drivers Tweeter 4 - 1" Diameter (2.54cm)
Silver Coil polyamide dome tweeters
Electrical Recommended Amplifier Power 1000 w/channel Crossover Isophase
Dimensions Cabinet Size 63-3/4" H x 21" W x 13" D
(161.93cm H x 53.34cm W x 33.02cm D)
Check this company web page for more info: http://www.polkaudio.com/homeaudio/products/recent/srs/?print=1
Customer Reviews:
http://www.polkaudio.com/homeaudio/products/recent/srs/?reviews=1
A steal at only $850.00
Contact Don at: 903-793-8304 or 903-277-7190
Thanks!
Customer Reviews:
Thanks!
Mains - Polk RTI-12 (cherry)
Center - Polk CSI-5 (cherry)
Surrounds - Polk FXI-5 (black)
LFE Sub - Velodyne DPS-12
Main Amplifier - Carver TFM-35x
AVR - Denon AVR-987
AVR - Denon AVR-987
Post edited by quezwood on
That ad has been posted here before, not worth $850 IMO they are in need of some TLC and need to get into the hands of someone that could bring them back to life!! or someone that could pick them up for around $400 for parts!!
Overpriced
Agreed, I paid about that much for mine and they appear to be in about the same shape (thought mine had ratty black grill clothe, not ugly white). I put a TON of work and $ into them. In the end, were they worth what I have in them compared to what I could buy in new speakers with the same amount, absolutely. But have to agree with TFLF, the $400-$500 range is more realistic.2 Channel
Polk SDA SRS, Nakamichi Pa-5 Preamp, PA-7 Amp, Shenda (Jolida) SD100S CD Player (Sylvania Gold Brand 5751 & Amperex Holland, Orange Globe 12au7 tubes).
Home Theatre
Onkyo SR707, Samsung Blu Ray,Sony 400 Disc DVD Changer, Sony 46" LCD (Model?)
Speakers: Front L/R: JBL L7, Center: JBL LC1, Surround: TBD (likely JBL L1)
Car: Clarion 9255-DRX, Adcom GFA 4702, GFA 4404, Pioneer TS-A1702c (Front and Rear), 2 Boston Acoustics 12.5LF subs -
SDA-SRS in poor aesthetic condition are only worth $400--$500? Tough crowd here...
Those would not be my first choice...but...that seems low to me. I figured ~$850 was not unreasonable; and $700 would be a deal if all the drivers were correct and functional.
Guess I was wrong. -
my guess was 800 was a good price for a fully functioning fully original pair with the original interconnect cable.
is the cosmetic condition worth 50% ?
whats a good price for a pair in mint condish?My Living Room
source > Sony DA555ES >
Kenwood GE-74 > Marantz SR4400 > Rotel RB980BX > Polk SDA2.
Pioneer VSX-D909S > Carver TFM-25 > Polk SDA1c.
Pioneer Elite VSX-99 > PSB imageB25.
Marantz 2226 > Polk SDA CRS.
Yamaha RX-V690 > Velodyne Servo F1000.
source > Onkyo TX-DS898 > B&W CC6 (center), B&W DM603, B&W DM601, B&W Rock Solid (rears), B&W AS6.
Bedroom
source > Pioneer Elite VSX-92TXH> ML Quest, B&W DM600 (center), B&W DM601 (rears), Velodyne Servo F1000. -
It really depends on ypur abilities and desire to work on them. I personally wanted mine to look new. They needed new end caps, so I had all 4 of these and the side pieces remade and stained to match to match the furniture in the room ($280). Had to replace the grille clothe, and again, had this done by an upholstry shop with clothe I bought. Probably could have done it, bit preferred to know it would be done right. Material was like $40, labor about $300, which is probably a bit much, but for all 6 panels, I lived with it, and they look new.
If any drivers are bad, that can add up fast. Again, wanting mine to look new, I ordered 7 new drivers sincw they had dented cones. The ones here don't appear to have that issue.
Last but not least, I replaced all of the hardware on the drivers/crossovers. Ordered new bolts becaise some had rust on the caps. Not a big expense, but like $20 with shipping.
Also want to consider if they have the feet that screw into the bottom. Again, not a big cost and likely you would want to spike them anyway, but in a pinch the feet will work.
If you the drivers/tweets/radiators are all good, and especially if you can do any work they need ypurself, that price may be fine, but if you plan to bring them back to perfect condllition and habe to pay to have it done, you might be better waiting on a pair in excellent shape and paying more to get them.2 Channel
Home Theatre
adcomcyclone wrote: »It really depends on ypur abilities and desire to work on them. I personally wanted mine to look new. They needed new end caps, so I had all 4 of these and the side pieces remade and stained to match to match the furniture in the room ($280). Had to replace the grille clothe, and again, had this done by an upholstry shop with clothe I bought. Probably could have done it, bit preferred to know it would be done right. Material was like $40, labor about $300, which is probably a bit much, but for all 6 panels, I lived with it, and they look new.
it sounds like i would want to do all of the things you said as well....what would you pay or a perfect pair though?My Living Room
Bedroom
Me personally, for a set in excellent cosmetic condition, with fully functional drivers, I think the $1500 range would by my ballpark.
I have seen nice sets priced at this level, but they were not in my area (one reason I purchased the lesser condition set at the price I did).2 Channel
Home Theatre
He will take 5 and the pics I saw looked pretty good. I think 75 claims in fabric would make them look 8+Speakers: SDA-1C (most all the goodies)
I would do it for $500!!! and if one had about $1000 upgrade budget one would have a very nice set of speakers!!! -
Yep, just not what I am looking for but someone that is and close by should think seriously. If anyone wants to see the pics I received PM me your email address.
I agree upgrading crossover, rings, spike and tweets would be great but I think you could go slow and enjoy them as you made that journey.Speakers: SDA-1C (most all the goodies)
Definitely!!! if someone was looking for a bunch of spare parts $500 is a steal!! I would buy them just for that alone if I was close enough.. -
TFLF, do you know if the SRS cabinet is the same as the 1.2TL?Speakers: SDA-1C (most all the goodies)
Everything is the same on the exterior of SRS/1.2/1.2tl the only difference is each one has different internal bracing. I should also note if I recall right? that the original SRS wood caps were a solid wood and they would split now and then -
At $500, these are worth it. Someone grab em.2 Channel
Home Theatre
TOOLFORLIFEFAN wrote: »Everything is the same on the exterior of SRS/1.2/1.2tl the only difference is each one has different internal bracing. I should also note if I recall right? that the original SRS wood caps were a solid wood and they would split now and then
Yes,the end caps are solid wood, and the do split. It almost looks like one end cap is gone on the CL posting.2 Channel
Home Theatre
adcomcyclone wrote: »Yes,the end caps are solid wood, and the do split. It almost looks like one end cap is gone on the CL posting.
Not sure why you think that. Here is a pic of the tops he sent me.Speakers: SDA-1C (most all the goodies)
The OP should jump on these.
If they are still there next weekend I may have to grab them just to flip them. Recover, test, make a cable and clean up. I bet there would be a profit. ANd if the sound was good enough in what is a probably too small room I might keep them.Speakers: SDA-1C (most all the goodies)
BTW, what MW driveres are in the SRS, looked at the stickies and the diagrams and wiring docs do not show it.Speakers: SDA-1C (most all the goodies)
MW6503's all 16 of them..
TOOLFORLIFEFAN wrote: »MW6503's all 16 of them..
Thanks.
I contacted seller and if they are still there next weekend I may just go and get them.Speakers: SDA-1C (most all the goodies)
Looking at the post, the pic from the CL posting, it looks like the speaker rhat is upside down doesn't have the cap on what is the top. Maybe I am seeing.it wrong, but that is what it looked like to me.2 Channel
Home Theatre
If anyone wants these go for it but unless I hear from you I will most likely get them next weekend. I know for a fact he will take 500.Speakers: SDA-1C (most all the goodies)
Come on quezwood, you know you want them! You could take your time and have a fine speaker.Speakers: SDA-1C (most all the goodies)
thsmith,
Go for it. My discretionary funds are running low at the moment and these are bit further than I would like to go.
LMK if you get them. I would love to hear them. I have never had the chance.Mains - Polk RTI-12 (cherry)
AVR - Denon AVR-987
