Logitech Transporter SE
PrazVT
Not sure if this is old news - it's new to me. It looks like the Transporter is back in "Transporter SE" form. $1400 is a bit expensive, but still very interesting.
I haven't seen it on the Logitech site in recent months - so I assume they're reintroducing it.
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
NAD D3020 V2
Schiit Bifrost 2/64
Post edited by PrazVT on
Correct, though I bought a new Roku M2000 instead.
Way I figure, internet streams are all low-ish bitrate anyway, and the M2000 will play flac off ANY upnp source, not just the slimserver (which does not run on most NAS drives.
And 400$ is much cheaper than 1400.
Still, the transporter is damn sexy if you've got the money.I'm the Dude. So that's what you call me. You know, that or, uh, His Dudeness, or uh, Duder, or El Duderino if you're not into the whole brevity thing. -
I know - I already have a Touch + DACMagic another SB Classic so I personally can't justify getting one. But it's cool to see it's back.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
A newbie question, what is special about them ?
Story is the Logitech Transporter SE has a round filler in place of the large front panel selection knob; apparently no longer available. Lots of folks say they don't ever use the selection knob so not really a problem.
On 5-8 Feb Logitech had a coupon code logi-tse-2211 that reduced the SE to $999 which was a decent deal if one really wanted a Transporter, I would wait for another sale.
Personally I would say get a Squeezebox Touch which is far more current and supported, and may actually sound as good as the Transporter DAC.SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
Honestly, I think it's just the built in DAC, XLR outputs, and perhaps a better power supply (b/c you would be using the analog out).Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
I have a Squeezebox Classic that I had modded by Bolder Cable, and it's fantastic. I've read reviews of his mods that put them ahead of the Transporter. In my current balanced setup, I push the Squeezy through a dac so I have a balanced source. But in my prior setup, where I used the analog outs direct from the Squeezebox, I was amazed by how good it sounded. Built a power supply for it as well.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I'm going to bump this since the Transporter and Squeezebox in general has sparked my interest.
How does the SQ of Squeezebox compare to a wired connection? I currently run digital coax from my PC to my DAC via a USB 24/192 transport, and the SQ is great. It seems like the Squeezebox is a great device, but I wouldn't want to loose any SQ in the process... -
I'd be willing to bet SQ will be as good or better with the Squeezebox. Unless you plan on playing 24/192, I would just stick with a Squeezebox Touch and go coax into your dac. The Touch will give you up to 24/96 without upsampling. Transporter is overkill IMO.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Did you get the analog,digital or both done on yours at Bolder?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
How's the DAC in either the Touch or the Transporter? Are they worth using without an external DAC?
As for the actual DAC chip I believe the transporter uses the AKM AK4396 "Miracle DAC" which is a very fine #cruncher.
Both. I started off with the analog mods, then I got a dac and sent it back to Bolder for the digital mods. Since that post I've replaced that SB3 with a Touch to play 2496. I had the Touch modded by Wayne as well.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
You'll find it better than consumer grade cd players for sure. It's doesn't stack up to my Dac-2, but it holds it's own. A Touch just sold in the flea market yesterday for $230, still sealed. At prices like that, you can't beat the SQ. Especially when you consider it can play 24/96.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Wait a minute, I thought connecting the SB Touch to a DAC such as WS DAC-2 via coax will play 24/192 as is???Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
No, not true. I think 24/192 will play, but it will be down sampled. You need the Transporter to play 24/192 losslessly.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
I currently run digital coax from my PC to my DAC via a USB 24/192 transport, and the SQ is great....
Jake, what is your USB transport?
Ben2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Or... use a laptop in conjunction with a USB to SPDIF converter (like the Musical Fidelity V-Link or Audio GD Digital Interface) and forget the Squeezebox.
You can get a decent laptop for the price of a SB.
Upside: functionality
Downside: palmability
Just my 2 centimos
The Audio-GD Digital Interface with upgraded PSU. It is a fantistic unit that I probably will never upgrade.
falconcry72 wrote: »Or... use a laptop in conjunction with a USB to SPDIF converter (like the Musical Fidelity V-Link or Audio GD Digital Interface) and forget the Squeezebox.
Just my 2 centimos
Another huge thumb down is the laptop fan/heatsink noise. With the SB Touch - W4S DAC-2 - W4S ST-1000 combination, it's dead quiet in my listening area (well, until the music plays :biggrin:). Therefore I refuse to bring a computer in.Gears shared to both living room & bedroom:
Living room:
Bedroom:
Other rooms:
I have no desire for a computer in the rig. None. Been there, done that. Squeezebox is the only way to go. I love the fact that with the Squeezebox, you plug it in, put batteries in the remote, and use it. No drivers, no software to configure, no complications. I'm all for using the computer as a media library/server, but I don't enjoy using it as a player at all. Squeezebox all the way...Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
+1. Though I wish the Touch looked like the SB3. I like the electronic VUs on the 3 and Transporter. Of course the Touch has the color one, but it seems a little cheezy
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
so with a dac i only need the digital upgrade i reckonMain Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Yes. If you're interested in a Bolder-modded unit, I could certainly sell my SB3. You'd be quite happy with it as long as you're not after 24-bit playback. SB3 down samples 24-bit to 16. My SB3 has been demoted to a whole-house system that's nowhere near the level of SQ that could take advantage of the Bolder mods. But I needed the Touch because I've started putting together a decent 24-bit collection. I'd be happy to put my SB3 in the hands of someone who'd get some use out of it.Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Thanks, but i too am after the 24bit setup.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Ah, cool. Get the Touch. You won't be disappointed.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Reported65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
In case anyone wasn't aware of this, it came out about 2 weeks ago and retails for $1499.
http://www.logitech.com/en-us/speakers-audio/wireless-music-systems/devices/7934
It's $500 less than the original Transporter with the only difference being:
"The Transporter SE has the exact same technical specification as the Transporter, and therefore it delivers the same level of sound quality audiophiles strive for. The only difference between these two models lies in the access of the system's functions. On the Transporter SE, many of the functions that were previously accessed by the TransNav™ controller on the front of the unit are now accessed through the included remote control."
It was a very smart business move for Logitech to re-release this unit, and do it for $500 less than before. Lots of people were demanding they bring it back.
_____________________
instant payday loans
