Miles Davis Tribute Headphones
boomerfss
boomerfss Posts: 125
edited September 2011 in Electronics
I was thinking about picking up a set of Miles Davis Tribute in ear headphones. They are on sale at a local store (Visions Electronics) for $98.00. The original price was $498.00.
Does anyone have a set of these earphones? The reviews are pretty good.
I want them for when I travel. I do a lot of flying and the flights are usually 4-5 hours. I need a good set.
http://www.amazon.com/Monster-Miles-Davis-Tribute-Headphones/dp/B002TLUJB8
Onkyo HTRC 180
Polk Monitor 70 Series 2 Fronts
Polk CSi A6 Center
Polk PSW505 Sub Woofer
Polk Monitor 60 Series 2 Surrounds.
Harman Kardon HTSK18 Back Ceiling Mounted
PS3 Xbox
Post edited by boomerfss on
    txcoastal1 Posts: 13,519
    Just an FYI over the ear/noise cancelling head phones work much better...I have tried buds on a plane and although you don't really notice it until you try listening to music or watch a movie....the damn engine noise takes over....just my .02
    cheers
  • headrott
    headrott Posts: 5,496
    I cannot imagine that in ear headphones could be worth $500.00, or even $100.00 for that matter. That said, I have not heard them so I cannot comment on the actual quality. I just cannot imagine they can be worth that much because of the style of headphone they are. In ear headphones will never be as good as over the ear style headphones. Therefore, I don't think they can be worth that much. I would argue that they cost as much as they do:
    1) because they have Miles Davis' name on them
    2) they are made by Monster
    Enough said.
    Greg
  • rebuy
    rebuy Posts: 694
    Those are not headphones.
  • boomerfss
    Well, I think I will get them anyway and give them a try.
    Any recommendations for a set for flying? Either in ear or over ear.
    Thanks...
    Onkyo HTRC 180
    Polk CSi A6 Center
    PS3 Xbox
  • zingo
    zingo Posts: 11,258
    I have the Klipsch X10i which works great for traveling. They are not active noise cancelling, but they are ear-plug style which does block out a majority of the noise around you. I can sleep with them anywhere, the iPhone controls are nice, and the sound quality is great.
  • coolsax
    coolsax Posts: 1,826
    you'd probably do better asking thoughts about these on Head-fi.org. those guys are really into their iems and quite a few have no problem dropping $500 on a good pair.. that said.. while it is made by monster the miles davis IEMS get great reviews even from head audiophiles.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • Montoya
    Montoya Posts: 506
    Really good set of headphones and they work well on the plane as long as your using the correct tips. I use mine with a Ray Samuels heaphone amp and they are really nice plus they have a good warranty. I had the Klipsch custom 3 and these far exceed those the klipsch where good but these are that much better.
  • skrol
    skrol Posts: 3,488
    My experience with M'ter products has shown them to be of very decent quality. My only issue is that they seem expensive for what they are. However, if you can find a deal, such as you have, they should be great.
    I was skeptical about in ear headphones and tried a pair of Denon AH-C751 (mainly because I found a great deal) and have been very impressed. I replaced the silicone tips with Comply T-400 memory foam tips and am even more impressed.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
