Bolder Modded Squeezebox Power Supplies
Gaara
Gaara Posts: 2,415
edited September 2011 in For Sale (FS) Classifieds
Bolder Cable Modded Elpac WM075-1950 - Price: $85 shipped
This is a "wall-wart" type power supply upgrade for Squeezeboxes that was modified by Bolder Cable. The mods consist of replacing the diodes in the 5 volt section with HexFREDs, replacing all the capacitors with high quality, low ESR Panasonic caps, and installing the correct DC connector to fit the Squeezebox. This is a big step up from the tiny power supply that Logitech provides.
index.php?action=gallery;sa=view;picture=64418
Bolder Cable Modded Elpac WM220-1 - Price: $115 shipped
This is a "power brick" type power supply upgrade for Squeezeboxes that was modified by Bolder Cable. The mods consist of disabling the 12V section, replacing the diodes in the 5 volt section with HexFREDs, replacing all the capacitors with high quality, low ESR Panasonic caps, and installing the correct DC connector to fit the Squeezebox. This is a big step up from the tiny power supply that Logitech provides.
index.php?action=gallery;sa=view;picture=64422
Terms:
Accepting Paypal Gift, Paypal, or USPS money order. These are both used and show some light wear. I have feedback on here, Audiogon and on Head-Fi. For sale in the US only.
Post edited by Gaara on
  • rooftop59
    rooftop59 Posts: 8,120
    which squeezeboxes will these work with?
    Game Room 5.1.4:
    Bedroom 2.1
  • nspindel
    nspindel Posts: 5,343
    James, I'll take the WM220-1. Does that come with free delivery?
  • Gaara
    Gaara Posts: 2,415
    rooftop59 wrote: »
    As per Bolder: "Squeeze Box 2, 3 or Touch." for the WM220-1 and I believe it is the same for the WM075. I know the WM075 works fine for the SB2 and SB3, but would have to research if it works for the Touch.
  • Gaara
    Gaara Posts: 2,415
    nspindel wrote: »
    Of course. Pm coming your way.
  • nspindel
    Touch can use same power supply, i.e. either of these, as long as you're not using the USB on the Touch to power an external device.
  • dcmartinpc
    dcmartinpc Posts: 844
    Darn you nspindel! If he doesn't take the 220, I will. If not, I will take the 075, as long as it works with the touch.
    Really wanted the 220!!!!
    Don
    Living Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
    Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
    Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9
  • nspindel
    Gaara wrote: »
    Sorry, I meant free delivery in person! :wink:
  • Gaara
    Gaara Posts: 2,415
    Might be a possibility, and thanks for the heads up on the touch
  • nspindel
    Would be cool to hang, been a while. New toys to show off :)
  • nspindel
    dcmartinpc wrote: »
    Don
    Sorry dude :cool:
  • dcmartinpc
    nspindel wrote: »
    Sorry dude :cool:
    No problem, it seems I am always a little late ot the party! But, at least I got the little brother that will still make a BIG difference over the stock supply :smile:
    Don
  • Gaara
    Gaara Posts: 2,415
