Bolder Modded Squeezebox Power Supplies
Gaara
Bolder Cable Modded Elpac WM075-1950 - Price: $85 shipped
This is a "wall-wart" type power supply upgrade for Squeezeboxes that was modified by Bolder Cable. The mods consist of replacing the diodes in the 5 volt section with HexFREDs, replacing all the capacitors with high quality, low ESR Panasonic caps, and installing the correct DC connector to fit the Squeezebox. This is a big step up from the tiny power supply that Logitech provides.
Bolder Cable Modded Elpac WM220-1 - Price: $115 shipped
This is a "power brick" type power supply upgrade for Squeezeboxes that was modified by Bolder Cable. The mods consist of disabling the 12V section, replacing the diodes in the 5 volt section with HexFREDs, replacing all the capacitors with high quality, low ESR Panasonic caps, and installing the correct DC connector to fit the Squeezebox. This is a big step up from the tiny power supply that Logitech provides.
Terms:
Accepting Paypal Gift, Paypal, or USPS money order. These are both used and show some light wear. I have feedback on here, Audiogon and on Head-Fi. For sale in the US only.
Terms:
Post edited by Gaara on
which squeezeboxes will these work with?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
James, I'll take the WM220-1. Does that come with free delivery?Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
As per Bolder: "Squeeze Box 2, 3 or Touch." for the WM220-1 and I believe it is the same for the WM075. I know the WM075 works fine for the SB2 and SB3, but would have to research if it works for the Touch. -
Of course. Pm coming your way. -
Touch can use same power supply, i.e. either of these, as long as you're not using the USB on the Touch to power an external device.Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
Darn you nspindel! If he doesn't take the 220, I will. If not, I will take the 075, as long as it works with the touch.
Really wanted the 220!!!!
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
Might be a possibility, and thanks for the heads up on the touch
Would be cool to hang, been a while. New toys to show off
Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
dcmartinpc wrote: »Darn you nspindel! If he doesn't take the 220, I will. If not, I will take the 075, as long as it works with the touch.
Don
Sorry dude :cool:Good music, a good source, and good power can make SDA's sing. Tubes make them dance. -
Sorry dude :cool:
No problem, it seems I am always a little late ot the party! But, at least I got the little brother that will still make a BIG difference over the stock supply
