lsi15 with nordost flatline speaker cable
deseroner
deseroner Posts: 155
edited September 2011 in Speakers
who has tried nordost flatline speaker cables with there lsi line.I want to upgrade from my ebay 12 gauge speaker wire. will there be a difference.
receiver- pioneer elite sc-37 thx ultra w/kimber kable.pk14.
mains-lsi15 4ohm 250w modified&db840 nordost blueheaven spk/rca
center : snell xa1900 4ohm 250w,nordost flatline
subs-klipsch-ksw10/athena asp-4100
rear-OWM3 - 8ohm 100w
surrounds-klipsch rs-7 150w
amp-5ch.-aragon 3005 thx ultra 2 nordost blue heaven ls pc
power.c-bpt cpc/ps.soloist ci.
Post edited by deseroner on
  • gdb
    gdb Posts: 6,012
    edited August 2011
    Might be just me but....flatline just sounds bad for the name of anything life/music related.:eek::biggrin:
    EndersShadow Posts: 17,722
    edited August 2011
    BlueJeans Cable (Canare), Signal Cable, Audioquest FLX. Those are my personal recommendations.
  • Emlyn
    Emlyn Posts: 4,826
    edited August 2011
    I think the best advice is buy used cables, try them yourself with your system, and if you don't like them with your system sell them on to someone else to try. About all you'd be out is shipping costs if you don't like them or notice a difference.
  • deseroner
    edited August 2011
    Emlyn wrote: »
    well i got me a pair for 125 new ,should have them next week
  • PrazVT
    PrazVT Posts: 1,607
    edited August 2011
    Well let us know how you like 'em. I've been happy with Signal Ultras and Kimber 8TC (used), but haven't heard much about Nordost.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • Emlyn
    Emlyn Posts: 4,826
    edited August 2011
    Looking forward to seeing what you think of them initially and once you've had them in your system for a while. After a couple weeks use, you might want to put your current cables back and see if you can tell a difference.
  • mantis
    mantis Posts: 17,561
    edited August 2011
    Unless you have access to a wide amount of cables it's very difficult to really decide what works in your system and what doesn't fit. I have spend years and I have countless ways of getting anything I want into my system to try.
    As suggested , get them used and give them a test drive and VS them with what you are currently using. Then from there you can try other stuff and pick your favorite. Over and over you will learn how each wire sounds in your system and you will find what really works for you.
    I honestly found Audioquest FLX series 14-2 and 14-4 to work with most speakers and amps . It's very clear and makes all systems I have used it on sound their best including mine. For the money nothing even remotely comes close. Nothing does and I have tried so many different flavors. If you spend more with Audioquest , you get more. I really would like another pair of CV-8s. They where amazing.
    Good luck man , report back I say go for it.
    Dan
  • deseroner
    edited August 2011
    mantis wrote: »
    will do, next week.
  • sand viper
    sand viper Posts: 16
    edited August 2011
    I have Nordost Red Dawn speaker cables in my system. I upgraded from Audioquest Type 4 and the Nordosts made the Audioquests sound slow and a little dark. Why don't you try the Cable Co? They have a rather larger library of cables to try for what may or may not a reasonable about depending on your disposable income.
    Polk LSi9, Focal Chorus 714V, Marantz PM8004, Marantz SA8004, Oppo BDP-93, Pro-ject Debut III w/ acrylic platter and Ortofon 2M Bronze, Nordost Wiring
  • deseroner
    http://www.youtube.com/watch?v=rrHdCE9cLpI video of nordost in action
  • deseroner
  • Glowrdr
    Glowrdr Posts: 1,103
    Well that sounds like hell on my laptop. I would buy something else. Seriously? Why do poeple make audio clips of how well something sounds? It sounds as good as your system sounds! It's kind of like when Sharp came out with all of those commercials to "show" how great their picture looked with the yellow. Well.... looked pretty much like my Pannny did before the commercial.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Jer.War
    Jer.War Posts: 180
    Glowrdr wrote: »
    Good luck trying to explain that to the gullible masses ;) Instead sell them this sweet lepard reppeling rock I sell. It's expensive, but I have never spotted (yes I did) single one since I have owned them.... Works three times as well if you buy two!!!
    [The Ever-Evolving System
    LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
  • deseroner
    Glowrdr wrote: »
    well thats what i have a tiny mic on my camera.
  • Glowrdr
    deseroner wrote: »
    No hard feelings bro - didn't actually check/realize that it was your video. But yeah, it's kind of hard to make a video of how something sounds. Even with some $10k studio recording equipment - if I'm listening to it on some GPX bookshelf system, I'm not going to notice any difference between your video and the Midi file I downloaded back in 1986.
    Your speakers probably sound awesome - but unless someone has reference to what they sound like (which I do not) - there is nothing to compare it to besides the noise that is right in front of the listener.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • Glowrdr
    BTW - checked out a couple of your other vids. Nice MR2. I've got an '07 G35 that's been known to sneak up on a few cars here and there. lol Makes my '04 TL look like a Geo Metro.
    Pioneer Elite SC-37
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
  • TouchOfEvil
    TouchOfEvil Posts: 967
    On my headphone setup the left speaker sounded a little more refined but it's kinda hard to notice a difference from your in home setup, recorded on camera, to my headphones.
    I would certainly say you need a sub though. Bass sounded thin on both vids.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • deseroner
    Glowrdr wrote: »
    thanx, making it a full blown track car now.time attack car.got a stroker for it.
  • deseroner
    i have two subs, iam run the lsi15 in stereo mode when listening to music,subs are off , actually the bass sounds good in person, still have to modify that though, waiting on my axon true caps, i modded the left speakers with sonic caps.
  • TouchOfEvil
    deseroner wrote: »
    I see, sounds underwhelming on camera but it's hard to get the full sound this way of course.
    You might want to look into replacing the stock 8" driver with the db 8" replacement. I've done it and it does wonders for the lsi bass performance. Digs deeper, louder and cleaner vs the stock unit.
    Living Room Rig:D
    Xbox360/PS3/WII
    M.Br. setup:)
    Computer Rig:
  • jbooker82
    jbooker82 Posts: 1,627
    mantis wrote: »
    I am running a set of AudioQuest Type 8's for my front 3. They sound pretty good. All I have to compair them to is regular 12 gauge speaker wire. I just figured to get a good set of cables and be happy instead of playing mucical cables.
    I belive they are the same thing as CV-8's minus the 72V DBS.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
