Amp question
corrinthians
corrinthians Posts: 35
edited September 2011 in 2 Channel Audio
I just got Monitor 70s. My receiver does not have preouts. Could I use this amp to power them? The amp is a AudioSource Amp310 which also has speaker level inputs. Money is the issue. At this time I cannot afford to buy a receiver and an amp.
http://www.bhphotovideo.com/c/product/548194-REG/AudioSource_AMP_310_AMP310_Power_Amplifier.html
Receiver: Pioneer VSX-1121K
Front: Polk Monitor 70 II (cherry)
Center: Polk CS2 II (cherry)
Surround: Satellites from my previous HTIB
Subwoofer: Outlaw LFM-1 EX
Post edited by corrinthians on
    tonyb Posts: 33,065
    What makes you think your receiver can't drive the 70's as is ?
  • corrinthians
    it's a 5.1 channel at 100watts per channel. I want to improve the sound as much as possible by being as frugal as possible (something to get me by for a couple of years until I can afford to get a nice reciever).
  • rebuy
    rebuy Posts: 695
    I take it you are not happy with the way it sounds? How long have you had the monitors?
  • corrinthians
    There's not much low end. I'm assuming if they had more power, they would sound better all around including more low end.
  • Systems
    Systems Posts: 14,873
    ...+1...yep thats about it..more power= more low end..=better sound stage..better robust sounding system..yep...all the way around better for your ears too..:cool:
    Testing
    Testing
    Testing
  • nwohlford
    nwohlford Posts: 700
    What receiver are you using? For $350, you should be able to get a much better receiver (especially if you looked used and don't need all the new bells and whistles).
    Or you could for $350 get a used receiver (or preamp) and add a used amp.
    What are your requirements (e.g.., how many speakers, do you need surround processing, hdmi, 3D).
    What are your sources?
  • decal
    decal Posts: 3,205
    ctank wrote: »
    Sometimes true, sometimes not.
  • Systems
    decal wrote: »
    ..not..always most of the time true..Sometimes.Only if you use the right power watts pre-channel..x2..or x5 or7..to the power..lolo..:eek:j/kin..decal...lolo..:wink:
    Testing
    Testing
    Testing
  • doctor r
    doctor r Posts: 837
    Reported
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
  • halo71
    halo71 Posts: 4,628
    Are you running a subwoofer in this set up?
    --Gary--
  • Systems
    +1@halo71..A sub would help out more with the M70's..There where built with that i mine..
    Testing
    Testing
    Testing
  • corrinthians
    No, i'm not using a sub
  • rebuy
    rebuy Posts: 695
    I don't know that you have them hooked up correctly if you're not getting much bass. I have 2 pair of RTI4's and they put out a decent bass line for bookies.
    You need to double check your connections and make sure your jumper plates are connected right.
    tonyb Posts: 33,065
    Make sure they are set to large in the receivers menu also.
  • BlueFox
    BlueFox Posts: 15,251
    With all these **** ads if mine got any bigger I would need to buy a larger house.
  • Splif
    Splif Posts: 114
    Can someone explain to me the difference between using the OP's example for external amplification vs using a recevier with preouts and a seperate amp? I don't need a totally indepth explanation. Just something I can understand in lamens terms.
    Pn51D550
    Panasonic DMP-BDt110
    Onkyo HT-RC360
    Polk Monitor 60's L/R
    Polk CS2 C
    Polk Monitor 30's SL/SR
    BIC F12
    XBOX 360 COD:MW2 250g edition
    Logitech Harmony One
  • fbm211
    fbm211 Posts: 1,488
    If your receiver has preouts you should consider getting a used baby adcom.(GFA-535)Its an awsome amp and can usually be had for around $100.00
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • fbm211
    fbm211 Posts: 1,488
    I just looked at your link.You could get a GFA-555 with that budget.
  • funcity
    funcity Posts: 10
    Adcoms would be a good choice!
