New pics up on the showcase. "Overkill"
joeparaski
joeparaski Posts: 1,865
edited September 2011 in The Clubhouse
Ok, so now that it's working I posted some new pics of "Overkill" in the showcase (joeparaski)
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
  • nadams
    nadams Posts: 5,877
    Can you give a quick rundown of what amps power what? Just curious.
    Ludicrous gibs!
  • joeparaski
    SAE 2600 (400/ch.) and SAE 2500 (300/ch.) run the SRS in bi-amp mode.
    SAE 2600 runs the dual SVS
    SAE 2400 (200/ch) runs the center sub
    SAE 2400 runs the center speaker
    SAE 2400 runs the side surrounds
    SAE 2400 runs the rear surrounds
    SAE Mk IVDM (100/ch) runs the side axis speakers
    Buttkicker amp runs dual tactile transducers
    Joe
  • Rivrrat
    Rivrrat Posts: 2,101
    And that is why my sig tag deleted itself. :tongue:
    I'm not sure what to say other than very nice.
    My equipment sig felt inadequate and deleted itself.
  • BeefJerky
    BeefJerky Posts: 1,319
    "Overkill" isn't even an adequate word to describe that system. I think you need to write Merriam-Webster and have them invent a new word for you.
    nooshinjohn Posts: 25,118
    "Overkill" is an "understatement".
  • DMara
    DMara Posts: 1,434
    joeparaski wrote: »
    Joe
    How much can your electric bill go up to? :biggrin:
    Gears shared to both living room & bedroom:
    Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
    Living room:
    LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
    Bedroom:
    Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
    Other rooms:
    Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
    audio-gd NFB-10.2 / Denon AH-D7000
  • stuwee
    stuwee Posts: 1,508
    Where's the showcase? I'm having a small get together, and I've been drinkin' :tongue:
    I'm a big fan of your SAE gear Joe.
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • Sherardp
    Sherardp Posts: 8,038
  • engtaz
    engtaz Posts: 7,654
    Sweet setup Joe.
    engtaz
  • stuwee
    stuwee Posts: 1,508
    Sherardp wrote: »
    Thanks! Joe you're giving Wardsweb a run for his money :tongue:
  • joeparaski
    DMara wrote: »
    Don't know how much the electric bill went up. But I did go look at the meter spinning outside one time when "power watching" a movie and I can tell you that it was spinning pretty fast.
    Joe
  • nadams
    nadams Posts: 5,877
    How many power circuits?
    Ludicrous gibs!
    Joe, that's one heck of a HT there. Really nice work setting that up! Must sound 'fantastic'!
    Careful, you might have us 'visiting'! lol Actually, I've been to Quebec a few times, it' only a few hours from here--and always very welcoming.
    cnh
  • Drenis
    Drenis Posts: 2,871
    Beautiful setup.
  • decal
    decal Posts: 3,205
    BeefJerky wrote: »
    I think overkill is a pretty accurate discription.:wink:
  • falconcry72
    falconcry72 Posts: 3,580
    Joe,
    Speakers look great. I like the black tops.:cool:
    I saw you're looking to upgrade your center. Get a Monitor 10, or 7. You won't be sorry. Slap some 194's in and it'll be timbre matched to your mains, plus either of those Monitors can handle serious bass. I like the 10 as a center because it has (2) midwoofers for a slightly wider, better integrated sound.
    You could also do dual CRS+'s above and below the screen, but you'll have to rewire them to get rid of the SDA effect, or just not use the interconnect, but then you'd only be using one midwoofer per speaker.
    Either way, I have found that using a vintage Polk as a center is the best match for vintage Polks as fronts.:wink:
  • byfthalone
    byfthalone Posts: 345
    if ya got 'em...flaunt 'em....
  • mole'
    mole' Posts: 3,160
    Droooool!!!!!!!!!!!!
    mole'
  • TECHNOKID
    TECHNOKID Posts: 4,298
    DMara wrote: »
    Sherardp wrote: »
    What you omit to metion to DMara is that Hydro Quebec is cheap compared than any other power companies of the RoC or any US providers (that doesn't stop us from complaining though :tongue: ). :wink:
    Joe, I know you are using commercial rack mounts for your set-up. Would you have any comments/pointers for me please ( http://www.polkaudio.com/forums/showthread.php?t=123409 )?
    Gadaman24 reported for SPAMMING this fine thread! :wink:
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
