New pics up on the showcase. "Overkill"
joeparaski
Ok, so now that it's working I posted some new pics of "Overkill" in the showcase (joeparaski)
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
Can you give a quick rundown of what amps power what? Just curious.Ludicrous gibs!
SAE 2600 (400/ch.) and SAE 2500 (300/ch.) run the SRS in bi-amp mode.
SAE 2600 runs the dual SVS
SAE 2400 (200/ch) runs the center sub
SAE 2400 runs the center speaker
SAE 2400 runs the side surrounds
SAE 2400 runs the rear surrounds
SAE Mk IVDM (100/ch) runs the side axis speakers
Buttkicker amp runs dual tactile transducers
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
And that is why my sig tag deleted itself.
I'm not sure what to say other than very nice.My equipment sig felt inadequate and deleted itself. -
"Overkill" isn't even an adequate word to describe that system. I think you need to write Merriam-Webster and have them invent a new word for you.
"Overkill" is an "understatement".The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
joeparaski wrote: »SAE 2600 (400/ch.) and SAE 2500 (300/ch.) run the SRS in bi-amp mode.
Joe
How much can your electric bill go up to? :biggrin:Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Where's the showcase? I'm having a small get together, and I've been drinkin'
I'm a big fan of your SAE gear Joe.Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
Sweet setup Joe.engtaz
Thanks! Joe you're giving Wardsweb a run for his moneyThorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
Don't know how much the electric bill went up. But I did go look at the meter spinning outside one time when "power watching" a movie and I can tell you that it was spinning pretty fast.
Joe, that's one heck of a HT there. Really nice work setting that up! Must sound 'fantastic'!
Careful, you might have us 'visiting'! lol Actually, I've been to Quebec a few times, it' only a few hours from here--and always very welcoming.
Beautiful setup.
I think overkill is a pretty accurate discription.If you can't hear a difference, don't waste your money. -
Joe,
Speakers look great. I like the black tops.:cool:
I saw you're looking to upgrade your center. Get a Monitor 10, or 7. You won't be sorry. Slap some 194's in and it'll be timbre matched to your mains, plus either of those Monitors can handle serious bass. I like the 10 as a center because it has (2) midwoofers for a slightly wider, better integrated sound.
You could also do dual CRS+'s above and below the screen, but you'll have to rewire them to get rid of the SDA effect, or just not use the interconnect, but then you'd only be using one midwoofer per speaker.
Either way, I have found that using a vintage Polk as a center is the best match for vintage Polks as fronts.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
if ya got 'em...flaunt 'em....
Joe, I know you are using commercial rack mounts for your set-up. Would you have any comments/pointers for me please ( http://www.polkaudio.com/forums/showthread.php?t=123409 )?
Gadaman24 reported for SPAMMING this fine thread!DARE TO SOAR:
