Earthquake Supernova MK15
Crystalclear
Crystalclear Posts: 196
edited March 2004 in Speakers
Do any of you have experience with this sub and what are your comments about it.I'm thinking about buying one and wanted some feedback on these.:)
Old School stuff
Sunfire Theater Grand Processor
Sunfire Cinema Grand 225x5 Amp
Monster AVS 2000 Signature
Polk RT800i's
Polk CS400i
Polk FX500's
(2) 2700 watt Sunfire Signature Subs
65' HDTV Mitsubishi Widescreen
  • gatemplin
    gatemplin Posts: 1,595
    edited March 2004
    I havent heard it but in that price range you should also consider the SVS PB2+ and the Acoustic Visions Denali with the bad **** Tumult.
    http://www.acoustic-visions.com/~acoustic/products/subwoofers/pre_finished/pinnacle_denali.shtml
    [IMG]C:\Documents and Settings\Templins\My Documents\My Pictures\pinnacle_denali_002.jpg[/IMG]
    Graham
  • Airplay355
    Airplay355 Posts: 4,298
    edited March 2004
    i've listened to earthquake subs....i think it was the one before that one in the line though. i thought is sucked, horribly....it was loud but forget about deep. this bass could not be felt at all and after a while it just got plain annoying. i was listening to the gun shoot out in the first matrix movie. and usually you can feel those bullets and the bass fills the whole room. this was not the case with the earthquake, i was very disappointed with it. the stereo guy there decided i would only be happy with a 15" woofer because i didnt like the earthquake. am i a bass head? maybe, but i wouldnt call anything from that woofer bass.
  • Crystalclear
    edited March 2004
    Airplay,Whoa!Really it sounded like ****?I thought they were supposed to be better than the Sunfire line of subs.I just sold my Sunfire Signature and wanted something bigger, and more powerful. I thought this was it!:confused:
    Old School stuff
    Polk RT800i's
    Polk CS400i
    Polk FX500's
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited March 2004
    The PB2+ should be significantly lower priced and probably better.
    http://www.svsubwoofers.com/subs_pb2_plus.htm
    It's doubtful that the Earthquake would be much competition for the similarly priced Ultra.
    http://www.svsubwoofers.com/subs_pb2_ultra.htm
  • goingganzo
    goingganzo Posts: 2,793
    edited March 2004
    i would say it is becues 1 Tumult has the output of 2 tempests and 1 tempest is about equivilent to 1 svs plus. the thing that is good about the Tumult is you get alot out of a small package but you need alot of power.
  • PolkWannabie
    edited March 2004
    Sunfire ( Carter ) makes/made some good products, but imho their subs are not among them.
  • gatemplin
    edited March 2004
    The Denali has a 1kW class D amp. I have a Tempest in a room over 3000 cubic feet and it is overkill with 250W.
    Graham
  • Crystalclear
    edited March 2004
    Ok the Denali's got my attention.Is there a dealer that sells these below MSRP from the manufacture???I wonder if someone has a demo that they want to sell?:)
    Old School stuff
    Polk RT800i's
    Polk CS400i
    Polk FX500's
  • gatemplin
    edited March 2004
    Talk to Kyle Richardson at Acoustic Visions, he makes them and only he sells them. I dont think you will find any demos but it cant hurt to try. Of course you could try building it yourself and he will give you advice along the way.
    Here's a dude who built his own Denali, check out the pics:
    http://hometheatertalk.com/httalk/viewtopic.php?t=5923
    Graham
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited March 2004
    Per Craigsub's review over at HT-SPOT, the Denali and the PB2+ are a virtual dead-heat in THD-limited output at all frequencies from 16 Hz on up. Really speaks highly of both designs and drivers. The Tumult is one serious woofer and a deal for $500.
    SVS
  • Airplay355
    edited March 2004
    yes, i hated the earthquake....i would prefer no sub then to have that one. the only sunfire i heard had problems with the driver, something was broken but it was "fixed" so it could still be used....it wasnt at its peak performance though. i prefered the broken sunfire to the earthquake. i think your money will be much much better spent elsewhere. i would quickly dismiss any thoughts of buying an earthquake sub. their name implies big sound and lots of boom when all you get is loud 40 hz bass and a quick drop off.
    this is my expirence with earthquake subs, im not tryin to degrade neone. kinda sad that i have to write this at the end of a post but oh well i dont need to become the next sid lol
