Wiring PSW404 sub and LSi15 front speakers
bbeacham
bbeacham Posts: 141
I currently have the PSW404 sub wired to the front left/right speaker outputs of the amp (Sony STR-DA3000ES) and the LSi15 front speakers come off the sub. The speakers are set to "large" and "no sub" on the amp.
Should I be using the sub output on the amp (appears to be an RCA cable) and directly connect it to the sub and just have the front speakers on the speaker output?
I have to admit that the related equipment (speaker and amp) manuals are not very clear on this subject.
Thanks.
Post edited by bbeacham on
  • fireshoes
    fireshoes Posts: 3,167
    edited March 2004
    Polk says speaker wire. Most everybody on here will say sub cable. Try both and see what you like.
  • del44
    del44 Posts: 686
    edited March 2004
    If your preference is more towards music, you may want to have the lsi's play independently from the 404. They are a great sounding speaker all by themselfs. Select sub yes ,front large. That way, when listening to movies you got the sub a thumping, or when listening to music, just use 2 channel mode on your receiver and you get the lsi's all by themselfs. Sweeeet. Experiment with different set-ups and see what you like.
