Wire Guage and more
sborras83
sborras83 Posts: 1
edited September 2011 in Basic Hookup/Wiring Questions
New to the HT arena. After listening to a couple of different speakers (Energy, Klipsch and Polk) and given my budget $1000. Decided to go with the following:
monitor 60 series 2 - Front
cs2 - Center
monitor 30 - surround
BIC F12 - Sub
Yamaha rx-v667 - receiver
Room dimensions are 20x16 opening to my kitchen.
Everything should arrive sometime this week. I already ordered 14awg wire from monoprice and then upon reading see that most of you recommend 12 guage. First noob question is will it make that much of a difference to me if I have 14 guage? I mean its only $30-40 so if it really makes that much difference I will get the 12. Second is since I am not using a 7.1 setup should I bother with bi-amping my m60's once I hook them up? or is this something that is not necessary.
  • B Run
    B Run Posts: 1,888
    edited August 2011
    The 14 awg is just fine unless you're making really long runs, and I wouldn't even bother with the Bi-wiring, just replace the brass jumpers with speaker wire, it sounds better.
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2011
    Bigger is better with inexpensive wire. As you said, the cost difference is negligible.
  • TouchOfEvil
    TouchOfEvil Posts: 967
    edited August 2011
    your fine with that 14gauge unless you plan to run it like 70feet.
    Living Room Rig:D
    Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
    Xbox360/PS3/WII
    M.Br. setup:)
    Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
    Computer Rig:
    Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
    Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's
  • newbie308
    newbie308 Posts: 846
    edited August 2011
    I dont know if it is still on sale, but Parts Express had some 25 foot coils of 10 AWG speaker wire on sale for about $9 a roll. I used it and it sounded much better than the 16 AWG wire I purchased a Lowes.
    Only problem is that it is dificult to hide speaker wire that is 7/8" wide!
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2011
    newbie308 wrote: »
    Do you have a link? Only thing I could find for that price is a 50ft roll of 14ga wire. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=109-160
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • newbie308
    edited August 2011
    I just looked, and the wire was a special factory buyout. They no longer have any in stock! Sorry!
  • djperez81
    djperez81 Posts: 388
    edited August 2011
    You should be fine with the 14 guage, your really not going to be able to hear the difference between the 2. I wouldnt bother bi-amping either. If you have a few extra bucks get a decent sub cable.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Mr. Sharpe
    Mr. Sharpe Posts: 1,359
    edited August 2011
    #9 reported for spam.
    Home theater:
    43” Westinghouse Displayer
    Marantz UD-7007 Player
    Emotiva MC-700 Processor
    Adcom GFA-5006 Amplifier
    Parasound Zamp Amplifier
    Ethereal ESO-1 Power Conditioner
    Klipsch RC-10 Center
    Klipsch R34c Fronts
    Klipsch RB-41 Surrounds
    Polk audio PSW-505
    Stereo:
    Polk audio RTA-12c’s fully upgraded crossovers
    DIY 12tc braided speaker cables
    Denon DVD-5910ci Spinner
    Parasound P6 Preamplifer
    Parasound HCA -1500a Amplifier
  • dekuda
    dekuda Posts: 756
    edited August 2011
    Good buys and good cable at monoprice....but they only go down to 12ga
    http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239
    HT System
    Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ.
  • Mr. Sharpe
    edited August 2011
    We all know this forum is not for advertising b.s. and scams don't we? lol
    #10, REPORTED
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited August 2011
    dekuda wrote: »
    I just got 16 pairs of their banana plugs and they rock! nice build quality and work really awesome! easy to use. only gripe is having to strip 12 gauge down so it'll go in, then you have to make sure it's the correct length or you have to keep trying... can be annoying, but they clean connections up nicely:biggrin:
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • halo71
    halo71 Posts: 4,645
    edited August 2011
    xcapri79 wrote: »
    The guide prepared by Roger Russell is a good reference to use.
    You again? :rolleyes:
    --Gary--
  • dekuda
    dekuda Posts: 756
    edited August 2011
    Mr. Sharpe wrote: »
    #10, REPORTED
    There is nothing wrong with helping members find good products at good prices. No BS or scam here. Maybe you should check out threads in the clubhouse where good online buys are advertised all the time........ report me all you want :rolleyes:
    HT System
  • Mr. Sharpe
    edited August 2011
    No, I reported a spam post. I didn't mean it to look like I reported you. I am sorry. it was something about Lighting and something else. I don't report a post unless it's worth reporting:)
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited August 2011
    xcapri79 wrote: »
    http://www.roger-russell.com/wire/wire.htm#wiretable
    FORGET THAT! 10 gauge 8 feet away!
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    edited August 2011
    halo71 wrote: »
    He's kinda like that chick you used to date in high school, the ugly one you were embarassed to be seen with, who keeps showing up when your with your new gorgous girlfriend.:tongue::biggrin:
    Just playin' with ya X....
  • halo71
    halo71 Posts: 4,645
    edited August 2011
    Like riding a moped? :tongue:
    --Gary--
    F1nut Posts: 52,406
    edited August 2011
    I have no idea what gauge my cables are and could care less. If gauge is what you're basing your decision on, you're already lost.
  • mantis
    mantis Posts: 17,689
    edited August 2011
    You should read the AWG. It's worth the time.
    Dan
    F1nut Posts: 52,406
    edited August 2011
    Why? It's not going to tell me how it sounds.
  • decal
    decal Posts: 3,205
    edited August 2011
    Everyone knows you MUST spend at least $800.00 for speaker cables to really hear your system !!!!!
  • Mr. Sharpe
    edited August 2011
    I didn't know that. I do appreciate that though:biggrin:
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • ROHfan
    ROHfan Posts: 1,014
    edited August 2011
    Keiko wrote: »
    audioholics . com / education? Boy! That some snake oil in and of itself right there.
    Why is it you feel that way? I read the site and found it quite informative. And most of it happens to be true.
    TV: 65" Samsung QLED 4K
    AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier
    F1nut Posts: 52,406
    edited August 2011
    Why is it you feel that way? Is it because you read it there and their mantra aligns with yours or it is from your own personal experiences?
  • Mr. Sharpe
    edited August 2011
    vroom vroom... chill mode.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • dekuda
    dekuda Posts: 756
    edited August 2011
    How is it that every thread that haves something to do with cables ends up being a rant/rave with the question of validity for cables? ( I try to stay away from these threads,LOL). Getting back to the OP's question, I think if you are going to make some speaker runs why not get the lower guage? Looking at Monoprice, the differance in price is not much and it is OFC. Even if you can not tell the differance why take a chance especially on long runs.
    If you have tried upgrading cables and you do not notice a differance ,fine, sell them.
    If you never have tried you will never know. :wink:
    HT System
    F1nut Posts: 52,406
    edited August 2011
    dekuda wrote: »
    Because they think they are going to save us from ourselves based on either a lack of experience or something they read.
    Bingo!
  • mantis
    edited August 2011
    Cool skip it then.
    Dan
  • thsmith
    thsmith Posts: 6,082
    edited August 2011
    Op, go to signalcable.com. Quality cables at a reasonable price.
  • Mr. Sharpe
    edited August 2011
    thsmith wrote: »
    Yes, they make pretty cables and they're not expensive what that quality.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
