Wire Guage and more
sborras83
New to the HT arena. After listening to a couple of different speakers (Energy, Klipsch and Polk) and given my budget $1000. Decided to go with the following:
monitor 60 series 2 - Front
cs2 - Center
monitor 30 - surround
BIC F12 - Sub
Yamaha rx-v667 - receiver
Room dimensions are 20x16 opening to my kitchen.
Everything should arrive sometime this week. I already ordered 14awg wire from monoprice and then upon reading see that most of you recommend 12 guage. First noob question is will it make that much of a difference to me if I have 14 guage? I mean its only $30-40 so if it really makes that much difference I will get the 12. Second is since I am not using a 7.1 setup should I bother with bi-amping my m60's once I hook them up? or is this something that is not necessary.
cs2 - Center
BIC F12 - Sub
Post edited by sborras83 on
The 14 awg is just fine unless you're making really long runs, and I wouldn't even bother with the Bi-wiring, just replace the brass jumpers with speaker wire, it sounds better.
Bigger is better with inexpensive wire. As you said, the cost difference is negligible.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
your fine with that 14gauge unless you plan to run it like 70feet.Living Room Rig:D
Rotel RSP-1069/Rotel RMB-1095/Rotel-1072/Polk lsI15's W/modded xoverW/DBsubs/Polk LsiC/lsI7's/Klipsch sub-12"the weak link"/DLP Mitsubishi 65"
Xbox360/PS3/WII
M.Br. setup:)
Emotiva MMC-1/Rotel RMB-1075/Polk BlackStone TL350's/Velodyne SPL1000/Samsung 51" Plasma
Computer Rig:
Rotel RB1050/Tannoy DC4's/Klipsch RW-10d/ImodIpod/HK AVR230 for now....
Headphones-Ultrasone-HFI780's w/LittleDot MK Vamp Portables Panasonic HJE-900's -
I dont know if it is still on sale, but Parts Express had some 25 foot coils of 10 AWG speaker wire on sale for about $9 a roll. I used it and it sounded much better than the 16 AWG wire I purchased a Lowes.
Only problem is that it is dificult to hide speaker wire that is 7/8" wide!Enjoying the journey while never attaining the destination. -
Do you have a link? Only thing I could find for that price is a 50ft roll of 14ga wire. http://www.parts-express.com/pe/showdetl.cfm?Partnumber=109-160Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
I just looked, and the wire was a special factory buyout. They no longer have any in stock! Sorry!Enjoying the journey while never attaining the destination.
You should be fine with the 14 guage, your really not going to be able to hear the difference between the 2. I wouldnt bother bi-amping either. If you have a few extra bucks get a decent sub cable.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
#9 reported for spam.Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier -
Good buys and good cable at monoprice....but they only go down to 12ga
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10239HT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
We all know this forum is not for advertising b.s. and scams don't we? lol
#10, REPORTEDHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
I just got 16 pairs of their banana plugs and they rock! nice build quality and work really awesome! easy to use. only gripe is having to strip 12 gauge down so it'll go in, then you have to make sure it's the correct length or you have to keep trying... can be annoying, but they clean connections up nicely:biggrin:Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
The guide prepared by Roger Russell is a good reference to use.
You again? :rolleyes:--Gary--
Mr. Sharpe wrote: »We all know this forum is not for advertising b.s. and scams don't we? lol
#10, REPORTED
There is nothing wrong with helping members find good products at good prices. No BS or scam here. Maybe you should check out threads in the clubhouse where good online buys are advertised all the time........ report me all you want :rolleyes:HT System
No, I reported a spam post. I didn't mean it to look like I reported you. I am sorry. it was something about Lighting and something else. I don't report a post unless it's worth reporting:)Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
http://www.roger-russell.com/wire/wire.htm#wiretable
FORGET THAT! 10 gauge 8 feet away!Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
He's kinda like that chick you used to date in high school, the ugly one you were embarassed to be seen with, who keeps showing up when your with your new gorgous girlfriend.
:biggrin:
Just playin' with ya X....HT SYSTEM-
lsi 9's -
Like riding a moped?
--Gary--
I have no idea what gauge my cables are and could care less. If gauge is what you're basing your decision on, you're already lost.Political Correctness'.........defined
President of Club Polk -
You should read the AWG. It's worth the time.Dan
Why? It's not going to tell me how it sounds.Political Correctness'.........defined
Everyone knows you MUST spend at least $800.00 for speaker cables to really hear your system !!!!!If you can't hear a difference, don't waste your money.
I didn't know that. I do appreciate that though:biggrin:Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
audioholics . com / education? Boy! That some snake oil in and of itself right there.
Why is it you feel that way? I read the site and found it quite informative. And most of it happens to be true.TV: 65" Samsung QLED 4K
AIYIMA Tube T7 preamp --- Nobsound 12AX7 tube preamplifier -
Why is it you feel that way? Is it because you read it there and their mantra aligns with yours or it is from your own personal experiences?Political Correctness'.........defined
vroom vroom... chill mode.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
How is it that every thread that haves something to do with cables ends up being a rant/rave with the question of validity for cables? ( I try to stay away from these threads,LOL). Getting back to the OP's question, I think if you are going to make some speaker runs why not get the lower guage? Looking at Monoprice, the differance in price is not much and it is OFC. Even if you can not tell the differance why take a chance especially on long runs.
If you have tried upgrading cables and you do not notice a differance ,fine, sell them.
If you never have tried you will never know.
HT System
Because they think they are going to save us from ourselves based on either a lack of experience or something they read.If you never have tried you will never know.
Bingo!Political Correctness'.........defined
Dan
Op, go to signalcable.com. Quality cables at a reasonable price.Speakers: SDA-1C (most all the goodies)
Yes, they make pretty cables and they're not expensive what that quality.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
