Sonic Barrier
VR3
I just wanted to say that this is a horrible product....
You will have to go to extreme lengths to make this actually attach to your MDF panels and if you did not put any extra adhesive on the backing when you attached it - it has fallen off.
No Rez is about double the cost but I just had to remove some of it and I had to pry it off the MDF. It actually took a little bit of the MDF with it.
All I am getting at - spend a bit more and go for No Rez or BH5 or whatever... anything other than Sonic Barrier. Its a waste of time.
That is all!
Have fun!
That is all!
Have fun!
Post edited by VR3 on
I haven't had any problems with the adhesive on Sonic Barrier. I do agree that BH5 is a better product,and I have yet to try No Rez.
Really?
Wow - I couldnt get it to stick with the Adhesive... pressed it as hard as I could and it literally falls right back off...
I think I had ONE piece stick to the surface...
In the past when I used it I just broke down and hot glued it in place (SM450)
I absolutely LOVE No-Rez. Danny Ritchie is a mad man.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
A spray adhesive or silicone will help keep it in place."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I thought these products dampen vibration by adhearing to the surface. So if your getting no adhesion then the product isnt working near as good as it should.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
To me if you have to buy a 10 dollar can of 3m adhesive spray you might as well spend 10 dollars more and get something awesome like No Rez... just saying...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
vr3mxstyler2k3 wrote: »to me if you have to buy a 10 dollar can of 3m adhesive spray you might as well spend 10 dollars more and get something awesome like no rez... Just saying...
smart man -
Did you dust out the cabinet first? I never had a problem with adhesion.
Oh yes! Always thoroughly cleaned. Cant get it to stick to save my life, lol.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
My cabinets were quite dusty inside. I wiped my cabinets down first with a damp cloth, let it dry thoroughly and applied the Sonic Barrier. It is stuck.
StanStan
Main 2ch:
HT:
Other stuff:
I've used Sonic Barrier in most of my speaker builds, and the results have been uniformly good.
That said, you can't expect a pressure sensitive adhesive to work well on an unfinished or rough surface. Not sure what your MDF is like. In my builds I use plywood (usually Baltic Birch) and finish with polyurethane on ALL SURFACES, both interior end exterior. The pressure sensitive adhesive holds well, and should last for a good number of years--but not forever. Like Scotch Tape, the adhesive will deteriorate over time and fail.
Cheers, JimA day without music is like a day without food.
