I want a new center channel:D
Mr. Sharpe
Mr. Sharpe Posts: 1,359
edited August 2011 in Speakers
what I have now just sucks! all it has are two full range drivers. Anything with a tweeter would be nice.
I'm looking at a JBL HLS center. they have one on amazon for $70 new:biggrin:
If not that, a Polk, that was the original plan so which one? I can only have an 8 ohm. I wish I could use one of their LSIC but not only is it 4 ohms but the sensitivity is 88Db would I'm sure my receiver would catch on fire if I used it:wink:
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Post edited by Mr. Sharpe on
  • Glowrdr
    Glowrdr Posts: 1,103
    edited August 2011
    Which system are you looking for? Might be tough to match the timbre with a DIY speaker. Might need to add a DIY center to match.
    65" Sony X900 (XBR-65X900E)
    Pioneer Elite SC-37
    Polk Monitor 70's (2)
    Polk Monitor 40's (4)
    Polk Monitor CS2
    Polk DSW Pro 660wi
    Oppo BDP-93
    Squeezebox Duet
    Belkin PureAV PF60
    Dish Network "The Hoppa"
  • Mr. Sharpe
    edited August 2011
    It will be used with the Cerwin Vega's, should I get a Cerwin vega center then? These are older speakers and I haven't very many pictures of this particular model online hardly at all.
    Naw my DIY's are in the 2 ch. stuff.
    Thanks for the help. I would just get any center speaker but I'd like some advice first, like some that would match the Timbre of the main speakers.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited August 2011
    I have a CS1 Polk that needs a new home, if interested PM for details. I've been meaning to put an ad up in the for sale section and will tomorrow after taking pics. $60 + shipping.
  • Mr. Sharpe
    edited August 2011
    TNHNDYMAN wrote: »
    Do you believe one of those would match a pair of these old Cerwin Vega's?
    picture.php?albumid=420&pictureid=4008
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • Mr. Sharpe
    edited August 2011
    Glowrdr wrote: »
    I will be using in my HT system. There's a list of speakers and there's a picture of the Cerwin Main speakers.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • halo71
    halo71 Posts: 4,630
    edited August 2011
    I've got a CV RE-6c center, if you are interested let me know.
    Here is what it looks like.
    --Gary--
  • HTguru1982
    HTguru1982 Posts: 1,066
    edited August 2011
    Probably not gonna find a better match for your CVs than that RE-6C.
    Display: Sony 42" LCD
    Sources: Harman Kardon DVD-27,
    Panasonic DMP-BDT110 blu ray player
    AVR: Sony STR-DA2400ES
    Amps: Sonance Sonamp 260(fronts),
    Kenwood KM-894(surrounds)
    Fronts: NHT 2.5
    Center: NHT VS-1.2A
    Surrounds: NHT Super One
    Subwoofer: SVS PB10-ISD
  • Mr. Sharpe
    edited August 2011
    Good deal. I'm still deciding between several different ones so thanks Halo and HT.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • 20hz
    20hz Posts: 636
    edited August 2011
    I got a polk cs300 I am not using ..
  • cubdog
    cubdog Posts: 835
    edited August 2011
    I have a few options but none better than halos CV. Go for it.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • TNHNDYMAN
    edited August 2011
    +1 go w/ Halo's CV center
  • 20hz
    20hz Posts: 636
    edited August 2011
    I really need to hear some of the new er CV's the last I heard was the older pink surround stuff they made and I was beyond impressed than !!
  • Mr. Sharpe
    edited August 2011
    I think the Pink surround speakers look cool and all but isn't that foam surround? I'm trying to stay away from cheapy stuff, the center I have now is cheap enough. two full range drivers, plain and simple. plenty of low muffled mid's and no really nice highs. I was listening to my Dad's Infinity center and was extremely jealous at how much better his sounded. something with a tweeter, maybe a horn since the mains have horns and good sensitivity.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • halo71
    halo71 Posts: 4,630
    edited August 2011
    Do what you will. But just because a speaker has foam surrounds does not mean it is a cheap speaker. :biggrin:
    --Gary--
  • Mr. Sharpe
    edited August 2011
    Does that one you have have foam or rubber surround?
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
  • halo71
    halo71 Posts: 4,630
    edited August 2011
    Foam. Think it listed for $300 new. Don't remember.
    --Gary--
    edited August 2011
    Seems to me halo does have your matching center.
    Two things:
    1. Are you CVs 'horn' loaded (that seems like a horn in there to me)?
    2. The surrounds in your pics actually look like they might need to be 'replaced'--is that an illusion of the photo or is the surround thinning out at points on both the mid and the woofer?
    cnh
  • Mr. Sharpe
    edited August 2011
    they are Horn loaded. You should've seen the surrounds before I cleaned them! They don't need replacing. there was a little section in the surrounds that looked to be cut open about an inch but I fixed it. Those are not the foam surround type either. There isn't a lot to the surround on the mids. I guess the mids could look that way because they came with a mesh grill over them originally, the original owner must've taken them off.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
    edited August 2011
    Well the question now is, is that tweeter in Halo's center a horn or not? Because that would be 'important' in matching your R/L speakers.
    I'd guess from the pics, no?
    cnh
  • halo71
    halo71 Posts: 4,630
    edited August 2011
    It is not horn loaded.
    --Gary--
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2011
    Mr. Sharpe wrote: »
    Front stage must be matched including the center. Stay away from miss-matching the front stage especially with newer speaker if you still want to keep that old pair of CV. Try get a used CV center that best match your present speakers.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • Mr. Sharpe
    edited August 2011
    the original plan was to get one with a horn loaded tweeter. I was thinking about something like either of these two
    http://www.amazon.com/Cerwin-Vega-Cmx-25C-5-Inch-Channel-Speaker/dp/B002JH1CKO/ref=sr_1_7?ie=UTF8&qid=1314744579&sr=8-7
    http://www.amazon.com/Cerwin-Vega-Xls-6C-6-Inch-Channel-Speaker/dp/B002JGZBJS/ref=sr_1_8?ie=UTF8&qid=1314744579&sr=8-8
    that was the Original plan. I hate to show interest in something like this then find out I need to match if tweeters are horn loaded or dome etc.
    Home theater:
    Klipsch R34c Fronts
    Polk audio PSW-505
    Stereo:
