SDA 1C RD0194 Orientation ?
Marty913
No doubt a stupid question however I don't know the answer so maybe not.
When replacing SL2000's with RD0194's, does it matter which terminal (silver or reddish) the white/black wires go to? Does it make any difference as long as both are the same?
Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica
TT = Audio Technica
Post edited by Marty913 on
Yes it does, the reddish one is the positive side and the white wire is the positive wire. The silver side is negative and the black wire is the negative wire.
It is important to have them correct or the tweeters will be out of phase and sound like crap. -
Thanks Joe, glad I asked and avoided the coin flip thing. Appreciate the quick response.
MartySony 60'' SXRD 1080p
TT = Audio Technica -
I think the black wire is positive and goes on the reddish post of the tweeter.SDA SRS 2.3TL's
SDA 2B TL's -
george daniel wrote: »black-blue-- positive
That's what I thought George. It's the opposite when you're talking about the 1.2TL's or 1.2's.SDA SRS 2.3TL's
SDA 2B TL's -
OK, time to get the screwdriver out. That was my original thought based on my previous SDA2's but I know various models can be different. That plus the mids on mine have red dots where the black/blue connect. I will switch them to Black/Blue = Red Post, White = Silver post.
Thanks GuysSony 60'' SXRD 1080p
I am sorry, I wasn't feeling well yesterday and totally flipped the wires in my head. Black/Blue is definitely the positive wire. I am losing my mind.
When in doubt, check the wiring diagrams, they are stickies in the vintage speakers forum. Schematics and wiring diagrams are invaluable...Good music, a good source, and good power can make SDA's sing. Tubes make them dance.
