Polk SR5250, SR104, C300.2, Arc Audio DXE and Tru SSLD6i
Kinda nice having all that stuff, look at it and think that i will find use for it one day but reality is that i just keep adding stuff to my "closet" lol, time to get rid of some.
Some items are used, some are brand spanking new, never installed.
All items are 100% functional and come in original boxes.
Used items have some blemishes but nothing crazy or out of the ordinary given that they were installed/used.
Prices are "all in" and include paypal and shipping fees except for SR104 subwoofers. See below.
I am in Staten Island, NY and local pick up is def welcomed.
Group shot:
POLK SR5250 - used - $300
5-1/4" aerated polypropylene woofer with UV- and temperature-resistant butyl rubber surround
7/8" ring radiator tweeter with multiple mounting options
die cast aluminum woofer basket
2-way external Zobel crossover network (3100 Hz, 18 dB/octave high-pass and 12 dB/octave low-pass) with four tweeter level settings
power range: 50-100 watts RMS (200 watts peak power)
frequency response: 60-30,000 Hz
sensitivity: 90 dB
top-mount depth: 2-1/4"
Group shot:
sensitivity: 90 dB
2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1
Kenwood DNX 5140
Post edited by Vital on
Would def be a step up from my db6501's
These subs are 30lbs each so shipping will not be cheap here. At least $50 for a pair i'd assume but i need to check on that. Local pick up is the best deal here as shipping will greatly increase total cost.
10" subwoofer with single 4-ohm voice coil
ABS plastic cone
cast aluminum frame
power range: 100-700 watts RMS
peak power handling: 1,400 watts
frequency response: 25-200 Hz
sensitivity: 84 dB
top-mount depth: 7-1/8"
sealed box volume: 1.0 cubic feet
Polk Audio designed their Signature Reference Series subwoofers to deliver superior performance ? you'll hear rich, warm lows, distortion-free clarity, and uncompromising accuracy. Polk packs plenty of advanced engineering into a sturdy, handsome package, so you'll get the impact you want from your system.
The SR104 10" subwoofer features a cast aluminum basket that offers supreme rigidity while virtually eliminating resonances. A sophisticated venting system keeps the sub's inner workings cool and dissipates heat from the voice coils.
The ABS plastic cone provides lightweight resilience and responsiveness, and its inverted arch shape minimizes the flexing which impedes clean bass output. A soft butyl rubber surround gives the cone plenty of room for excursion, while maintaining its shape over time.
Kenwood DNX 5140
Brand spanking new, only taken out of plastic to be drooled over and then to take these pics. Never seen power, never installed, comes with all paperwork/sticker/manual/wattage caertificate......
As you can see (and as every polk/momo amp) this amp does more then rated.
?150 watts RMS x 2 at 4 ohms
?220 watts RMS x 2 at 2 ohms
?550 watts RMS x 1 bridged output at 4 ohms
?stereo or bridged mono output
?4-ohm stable in bridged mode
?Tri-way capable (Tri-Way crossover required)
?Maximum Dynamic Headroom (MDH) power supply
?requires 4-gauge power and ground leads ? wiring and hardware not included with amplifier
?variable high- and low-pass crossovers, 50-250 Hz, 18 dB/octave
?subsonic filter at 15 Hz, 24 dB/octave (only operates with low-pass filter activated)
?6-way Smart System Protection circuitry guards against power and ground reversal, overheating and shorts, current overdraw, and low impedance
?Pre-EQ switch optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers
?RCA inputs accept both speaker- and preamp-level input (To use the inputs as speaker-level, you must attach RCA connectors to your speaker wire.)
?preamp outputs
?optional remote subwoofer level control
?dimensions: 13-3/8"W x 2-9/16"H x 9-3/4"D
If you're building an all-Polk system, check out this exclusive feature; the C300.2 features a Pre-EQ switch, which optimizes the crossover and bass level especially for use with Polk/MOMO full-range speakers and subwoofers!
Kenwood DNX 5140
Yeah, I keep thinking they are my next step in my car. I just got a 2 channel amp that is 200 wpc @ 2 ohm so I have more than enough power for these guys..... I could even run 2 sets and still be fine.....
and since its all wired, they would just need to switch the crossovers and reinstall the speakers.....
I hate seeing these For Sale because it makes me want to buy buy buy...
Hell makes me wonder how the SR subs compare to my Treo TE.... I could be all Polk + Sundown hmmmmm
Below are specs on it which probably will not tell you much but if you search around on diyma you'll find a LOT of reviews on this unit from users. There's not a single "bad" or even "it's ok" review, everyone that have/had this unit speak very highly of it. It's probably the best line driver there is that is also a line conditioner (whatever that means lol). Really thou, just look it up read for yourself.
MODEL
SSLD6
TOPOLOGY
Class A/B
CHANNELS
6 CH
FREQUENCY RESPONSE
10Hz ~ 150KHz +/- 0.5dB
FREQUENCY RESPONSE
20Hz ~ 20KHz +/- 00.2dB
THD+NOISE
< 0.009%
S/N RATIO
> 110dB
INPUT VOLTAGE
0.001V ~ 9.2V (Unity Gain)
OUTPUT VOLTAGE
1V:4.5V Ratio (13V Peak)
FUSE REQUIREMENT
1 Amp
POWER SUPPLY
9.5VDC ~ 15VDC
DIMENSION
3.5" x 4.125" x 1.375"
Kenwood DNX 5140
Never even taken out of plastic, everything is still sealed.
In the future all audio products will have the flexibility of a fully Digital Control System with the sweet smooth sound and perfect sound stage of an Analog Device. This was our goal when we set out to build the DXE. We use an advanced digital controller to operate all the features of a sophisticated Analog Crossover. The result is the channel tracking and frequency control of a fully digital crossover without the harsh mechanical sound that can accrue. For years home audiophiles have enjoyed Hi End Analog Systems that produce stunning sound stages and smooth harmonics. Now the DXE brings this level of performance to the car with the control of a fully digital crossover.
This truly Audiophile Crossover is coupled with a 5 Band Parametric Preamp EQ with fully balanced output and a Digital Control
Max input level: 8 volts RMS
Input sensitivity: 8V (0dB), 2V (10 dB), 700m(20 dB)
Max output level: 10 volts RMS
Input impedance: 47.5 K ohm
Minimum output impedance: 600 ohms
Harmonic distortion + noise: <.005
Frequency response: +/- 0.2dB
Separation at 1KHz "A" weighted: >78 dB
Signal to Noise "A" weighted: >108dB
Current requirements: 1.2 amps
5 Filters with +/- 15 dB at
20Hz-50Hz with Q of 2,
50HZ-100Hz with Q of 1.4,
100Hz-1KHz with Q of 1.1,
1KHz-10KHz with Q of 1.1,
10KHz with Q of 1.1.
Manual:
http://www.arcaudio.com/product-pdf/DXE_manual.pdf
Kenwood DNX 5140
Damn you guys are quick lol. I quess i need to practice my copy/paste technics lol
Yes, SR will blow db out of the water. Even the fact that it's 5.25'' vs 6.5''.
Then again i am the seller so my opinion could sound bias :biggrin:
Kenwood DNX 5140
Nah, I was aware of that, even as you said despite the size disparity. The problem is always funding.
Got some stuff that needs to sell to get up the funds.
Hell I might just sell my rear set of db6501's (or hell both sets) and not replace them until the car is getting ready to sell.....
Yeah, after doing a quick spec's compare the Treo wins. Mostly thought due to my amp being 1 ohm stable and being able to put out 1400 watts @ 1 ohm, 700 @ 2 ohm (Treo is a 4 ohm DVC wired for 2 ohm load), 360 @ 4 ohm (which is what these particular SR's are).....
My only though with keeping the other components is that I could wire both sets through my 2 channel amp and get all 4 speakers 100 wpc for each one....
Will be keeping my eye on this For Sale listing.......
GLWTS!
Kenwood DNX 5140
Right after i sold all of these lol.
http://www.polkaudio.com/forums/showthread.php?t=110136
I got it because i was sure to run active 3-way front + sub but it never really happened and i'm very happy with my current 2-way front (SR6500) + sub (SR124). I also got a fair deal on used Arc IDX/XEQ combo which is perfection when it comes to 2-way front + sub so i used that and think i'll stick with it.
Thank you
Kenwood DNX 5140
Kenwood DNX 5140
Kenwood DNX 5140
Friggin BOB SAGGETT!!!!!
Well my cash reserve is totally depleted.... But since my wife got a promotion this week I will just have to wait for the next set of em.
GLWTS.
Kenwood DNX 5140
Kenwood DNX 5140
Kenwood DNX 5140
Kenwood DNX 5140
Still have brand new
Arc Audio DXE: 4-way active crossover, eq, line driver
and brand new
Polk Audio/MOMO C300.2: 2-channel amplifier.
Kenwood DNX 5140
Kenwood DNX 5140
It always makes sense to have more wattage for woofers. Low frequencies require more power to achive punch/kick you expect to hear.
Congrats on getting SR6500, those are close to impossible to get nowadays. Did you get them from ebay last week? There were 2 listings there.
Kenwood DNX 5140
Im so excited to hear them but I have a big problem......my car front speakers are 5250ok and I bought some adapters for about 16u and turns out there the wrong ones so they don't fit my car and I really want them too:((((((((((( wanted to use the pa330 to power them for a bit till I got a new amp and hu
My car works with 6.5'' but apparantly not with 6.75'' which is what SR6500 really is.
Here's size differance of 5250 and 6500
and here's my door's speaker opening and sr6500 mounting bracket, you can see that openings is a bit less then needed.
I've marked what i need to cut off with red marker and dremeled it all out
and here's it is nice and neat:
Kenwood DNX 5140
I paid alot for them twice what I would of paid for the sr5250, I just really want to hear the sr6500
