Looking for Misc Audio Deals of the Day? Updated info here!
I found my best answer/opinions here:
http://www.polkaudio.com/forums/showthread.php?t=122239&page=2
Basically to each his own, but it's not a lemon.Polk Audio SDA CRS+ crossover 4.1TL by Trey/VR3 (Rings and custom stand by Larry)-Polk Audio SDA SRS2 crossovers by Trey/VR3Parasound HCA1500aYamaha rxa-3070 with musicast-Celestion SL6S presence,- sl9 surround backNHTsuper1's surroundMagnepan SMGParasound 1500pre- Sofia "Baby" tube amp - Monitor Audio Silver RX2 Marantz 2230/B&Kst140Technics 1200mk2 Gamertag: IslandBerserker I am but a infinitesimally small point meeting the line of infinity in the SDA universe -
http://rochester.craigslist.org/ele/2534257524.html
no affil, don't even know if it's a good priceSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Stupidest good deal I've seen in a while:
http://newyork.craigslist.org/mnh/ele/2542601062.html
Amazing deal, but need to get the speakers out of the apartment on Friday or Saturday.
This is a 7 speaker system. All speakers are coated with the black piano laquer (upgraded option).
Model: LSif/x RIGHT Serial #: AM216601350
Model: LSif/x LEFT Serial #: AM216501350
Model: LSiC Serial #: AM214503258
Model: LSi15 LEFT Serial#: AM221500488
Model: LSi15 RIGHT Serial #: AM221600972
Model: f/xi3 RIGHT Serial #: AM315604771
Model: f/xi3 LEFT Serial #: AM315504771
The value for the system is over $2600:
Search the follwing terms on ebay to see the values
LSI15 LEFT: I have a pair of these ~$1500 value
LSiF/X: I have a pair of these ~$500 value
LSiC: 1 of these $300
I also have 2 more rear speakers, which i couldn't find on ebay (value is ~$300)
This is obviously an amazing deal, I simply don't have a place to store them after Saturday.
I will also see the pieces separately if I can't get good value for the whole set. Will entertain any offers. -
^ Good lord that isnt much more than I bought JUST my LSi 15's for :eek:"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
PIONEER SC25 ON THE GON $545 http://www.audiogon.com/cgi-bin/cls.pl?homeproc&1318577071&/Pioneer-Elite-SC-25
Could be a decent buy depending on the model of the Adcom and the condition of the gear:
http://cincinnati.craigslist.org/fuo/2544570995.html
I have an email to get the model of the Adcom BTW."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Anyone in Ohio looking for a dedicated amp:
Carver AV-405 for 50 bucks.
http://dayton.craigslist.org/msg/2537521546.html
One of these is at Vintage hi-fi in Pitt for 225, so if it works your getting a steal
8-ohm FTC rated power/ch 100W
4-ohm FTC rated power/ch 150W
2-ohm dynamic power/ch 200W
Center Channel Power 110W
Rear Channel Power 50W
4/8-ohm FTC rated THD 0.1%
Input Impedance (Line) 47 kohms
Rated full power bandwidth 20-22kHz
S/N-IHF A-Weighted,dB >95dB
Dimensions (HxWxD inches) 4.4x19x15
Removable rack handles for 17" width. 5 channel amplifier for Dolby Pro Logic systems. Exclusive Power Enhancement CircuitTM for surround channels. Includes special protection circuits.
The AV-405 five channel power amplifier was designed specifically for use in home theater surround sound systems. When teamed with one of Carver's superb Dolby Pro Logic components (preamplifier, preamp/tuner, or outboard processor), the AV-405 provides power, flexibility far surpassing any single-unit receiver, yet does so at a comparable cost. With 410 watts of total output (8Ω loads), the AV-405 has ample power reserves for accurately reproducing peaks on digital soundtracks, even when driving low impedance loads. Elevated power output for the center channel, an exclusive Carver feature, provides better handling of dynamic peaks on the dialog tracks as well as more balanced, realistic soundtrack reproduction. The AV-405 shuns production shortcuts common in low-cost surround sound receivers. It employs all discrete circuitry in the output stage for greater long-term reliability and superior response to peak demands for simultaneous high current and high voltage. Robust power supplies ensure that all five channels can be driven to full power simultaneously – not always the case with receivers! In addition, the AV-405 incorporates Power Enhancement CircuitryTM, an exclusive Carver feature which allows higher undistorted volume levels on the rear surround channels. If you're ready to step up to the advantage of Home Theater separates, the AV-405 provides five channels of Carver power in one convenient package."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Pinnacle 12" subwoofer brand new, free shipping:
http://www.ebay.com/itm/Pinnacle-Speakers-12-200-Watt-Powered-Subwoofer-NIB-/260836384049?pt=Speakers_Subwoofers&hash=item3cbb0f5d31Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
SDA-2 on eBay right now for $20.00 local pick up. New York
LSI9s on audiogon - no affiliation:
http://www.audiogon.com/cgi-bin/cls.pl?spkrmoni&1319019352&/Polk-Audio-LSI-9
Erik Tracy wrote: »LSI9s on audiogon - no affiliation:
good price...local too...Video: LG 55LN5100/Samsung LNT4065F
Receiver: HK AVR445
Source: OPPO BDP-93
HT: POLK SPEAKERS RTi6, FXi3, CSi5, VTF-3 MK2
2Ch system: MC2105, AR-XA, AR-2A, AR9, BX-300, OPPO BDP-83 -
Anthem PVA-7 amp $650
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1317591012 -
They are sold. What price where they? -
Those LSi9's were $400 plus shipping...sweet deal!
thanks Juan, that is a REALLY smokin deal...No wonder they were gone so fast :biggrin: :mad: :biggrin: -
:eek::eek::eek:2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
Fair price for a Musical Fidelity A5 Integrated Amp on the 'gon:
http://www.audiogon.com/cgi-bin/cls.pl?intatran&1319245482&/Musical-Fidelity-A5-Integrate-Amp
No affiliation.
Hmmm...another set of LSi9s at a very low price:
http://www.audiogon.com/cgi-bin/cls.pl?spkrmoni&1319241626&/Polk-LSi9
No affiliation
....2 pair of DCM Time Windows....Pa.....would make AWESOME HT setup.
http://www.ebay.com/itm/SET-4-VINTAGE-FLOOR-STANDIN-DCM-TIME-WINDOW-SPEAKERS-/260838925934?pt=Speakers_Subwoofers&hash=item3cbb36266e -
How about a Massive NO DEAL on the list lol...
A Marantz 2325 with no price on the Indy CL. I emailed the seller, and they want 1k for it. I see a fully restored one that went for 600 and thats the highest price I found.....heck they sold for less than 800 WHEN NEW!
CL ad: http://indianapolis.craigslist.org/ele/2562412080.html
Sale for reference: http://www.classicaudio.com/forsale/mz/2325.html
Also found this which could be a decent deal Marantz 1120 for 400:
http://indianapolis.craigslist.org/ele/2554467906.html
Its shiny and my ADD makes me like it
Polk RT2000P in Ohio for $200.
http://www.ebay.com/itm/Polk-Audio-RT2000p-Speakers-sold-pair-ship-50-ea-/170685867971?pt=Speakers_Subwoofers&hash=item27bdaba7c3Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Provided those are in good shape, that's a stupid good deal
easy waf approvalSamsung pn64f8500
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
Now here is a sweet deal on a MF int amp:
http://www.audiogon.com/cgi-bin/cls.pl?intatran&1319431431&/Musical-Fidelity-A300
This should go pretty quick!
Erik Tracy wrote: »Now here is a sweet deal on a MF int amp:
Yup - already gone.
Overstock.com has the Wadia 170i iPod dock for $209.
http://www.overstock.com/Electronics/Wadia-Black-170i-iPod-Digital-Audio-Output-Transport/6128254/product.html
