My left LSi9 woofers cut out for 5 min last night ...
PrazVT
Very weird and I'll be watching them for the next few days to see if it happens again. Last night as I was swapping in some new Signal sub cables, I noticed that only the tweeter was active on the left speaker. These are modded btw.
Checked the speaker and IC connections and those were okay. hooked up the right speaker cable to the left speaker to make sure it wasn't the NAD acting up and it was the same for a sec and then the woofers came back on. Hooked everything back up and the system is fine again.
Any thoughts on what may have caused it? Perhaps a loose connection in the xo? There are 2 giant Daytons that are connected to the xo via leads. I haven't cracked the speaker open yet. If it happens again, I will though.
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups.
NAD D3020 V2
Schiit Bifrost 2/64
Post edited by PrazVT on
I would figure that ben would've put a healthy amount of solder on all of the connection points. I would take a peek inside to see if anythings awry though.
Sounds like a connectivity issue though.- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf -
Yeah you're probably right. If it happens again, I'll crack it open - I just don't want to potentially have to mess with it myself and then break something lol.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Did Ben do the mods? If so you may want to give doro a shout...
or me
- Computer Rig -
- Main Rig -
Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Okay - left speaker woofers are not coming in again ... time to open it up I guess.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Some photos as I can't see anything obviously disconnected or anything. Soldering looks in place and caps seem to look ok.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
I'll look at everything later. Do you know how to solder?- Computer Rig -
- Main Rig -
I have a soldering iron - but I haven't really done any soldering.
Can't get those blue connectors off of the big caps either, to take the xo out.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Thanks Jim, by the way.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
OK - you see the 2nd picture up there? the red wire got disconnected from the binding post. Do I just solder it back on?Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
UPDATE: Did a quick read-up on basics of soldering and then carefully soldered the wire back onto the lead. Looks solid and the speaker seems to be back to normal now
I suspect that the wire got disconnected but was making intermittent contact with the lead.
Random question - some of the screws on the speaker have gotten a little stripped from removing / replacing the drivers. Can I get replacements from Polk?Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
I PMed you my cell in case you need help with soldering.
Are the screws stripped or are the holes?- Computer Rig -
- Main Rig -
As mentioned on the phone, it's just some of the screw heads that are a bit stripped. I'll call CS one of these days and see if I can get some new ones. Thanks for the support dude!
I think soldering that wire back fixed the issue - speaker seems to be good now.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
Good deal. I'm sure Polk CS will get you squared away- Computer Rig -
- Main Rig -
Reported!DARE TO SOAR:
