My left LSi9 woofers cut out for 5 min last night ...
PrazVT
PrazVT Posts: 1,606
edited September 2011 in Troubleshooting
Very weird and I'll be watching them for the next few days to see if it happens again. Last night as I was swapping in some new Signal sub cables, I noticed that only the tweeter was active on the left speaker. These are modded btw.
Checked the speaker and IC connections and those were okay. hooked up the right speaker cable to the left speaker to make sure it wasn't the NAD acting up and it was the same for a sec and then the woofers came back on. Hooked everything back up and the system is fine again.
Any thoughts on what may have caused it? Perhaps a loose connection in the xo? There are 2 giant Daytons that are connected to the xo via leads. I haven't cracked the speaker open yet. If it happens again, I will though.
ALL BOXED UP for a while until I save up for a new place :(
Home Theater:
KEF Q900s / MIT Shotgun S3 / MIT CVT2 ICs | KEF Q600C | Polk FXi5 | BJC Wire | Signal / AQ ICs | Shunyata / Pangea PCs | Pioneer Elite SC 57 | Parasound NC2100 Pre | NAD M25 | Marantz SA8001 | Schiit Gungnir DAC | SB Touch
2 Channel:
Polk LSi9 (xo mods), Polk DSW MicroPro 2000 sub | NAD c375BEE | W4S DAC1 | SB Touch | Marantz SA-8001 | MIT AVt 2 | Kimber Hero / AQ / Signal ICs | Shunyata / Signal PCs
Post edited by PrazVT on
  • JimAckley
    JimAckley Posts: 1,138
    edited August 2011
    I would figure that ben would've put a healthy amount of solder on all of the connection points. I would take a peek inside to see if anythings awry though.
    Sounds like a connectivity issue though.
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    Yeah you're probably right. If it happens again, I'll crack it open - I just don't want to potentially have to mess with it myself and then break something lol.
    Home Theater:
    2 Channel:
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2011
    Did Ben do the mods? If so you may want to give doro a shout...
  • JimAckley
    edited August 2011
    or me :smile:
    - Computer Rig -
    - Main Rig -
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    Yeah Ben did the mods.
    @Jim - ie. you'd like to re-mod my xos? :)
    Home Theater:
    2 Channel:
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    Okay - left speaker woofers are not coming in again ... time to open it up I guess.
    Home Theater:
    2 Channel:
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    Some photos as I can't see anything obviously disconnected or anything. Soldering looks in place and caps seem to look ok.
    Home Theater:
    2 Channel:
  • JimAckley
    edited August 2011
    I'll look at everything later. Do you know how to solder?
    - Computer Rig -
    - Main Rig -
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    I have a soldering iron - but I haven't really done any soldering.
    Can't get those blue connectors off of the big caps either, to take the xo out.
    Home Theater:
    2 Channel:
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    Thanks Jim, by the way.
    Home Theater:
    2 Channel:
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    OK - you see the 2nd picture up there? the red wire got disconnected from the binding post. Do I just solder it back on?
    Home Theater:
    2 Channel:
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    UPDATE: Did a quick read-up on basics of soldering and then carefully soldered the wire back onto the lead. Looks solid and the speaker seems to be back to normal now :) I suspect that the wire got disconnected but was making intermittent contact with the lead.
    Random question - some of the screws on the speaker have gotten a little stripped from removing / replacing the drivers. Can I get replacements from Polk?
    Home Theater:
    2 Channel:
  • JimAckley
    edited August 2011
    I PMed you my cell in case you need help with soldering.
    Are the screws stripped or are the holes?
    - Computer Rig -
    - Main Rig -
  • PrazVT
    PrazVT Posts: 1,606
    edited August 2011
    As mentioned on the phone, it's just some of the screw heads that are a bit stripped. I'll call CS one of these days and see if I can get some new ones. Thanks for the support dude!
    I think soldering that wire back fixed the issue - speaker seems to be good now.
    Home Theater:
    2 Channel:
  • JimAckley
    edited August 2011
    Good deal. I'm sure Polk CS will get you squared away
    - Computer Rig -
    - Main Rig -
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Reported!
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
