Cheer and cheerful 24/192k DAC
FTGV
FTGV Posts: 3,650
edited March 2013 in DIY, Mods & Tweaks
Make that Cheap and cheerful.
I spotted this little kit while surfing ebay and thought that it appeared to have a lot of potential if important erea's were given special attention.Since niether of my current DAC's have 192k capability this looked like a economical way to try the few high sampling downloads that I have stored on my PC at their full resolution.
The kit I purchased did not include the chassis,transformer ,connectors etc.
It came with a blank PC board with the exception of having the three SMT IC's already soldered (the DAC,DIR and logic).All the other parts to populate the board are included .For the price the parts are of decent quality but since they are standard hole through types they are much easier to find suitable higher quality substitudes,which ofcourse is what I did.Since board real estate is at a premium there is no room for exotic film caps etc.
I opted for Nichicon HE and UCC KME's for main filter caps.I used Panasonic FC's for local decoupling, bypassed by Panny stacked films. WIMA film's were used the PLL filter and BC polyprop's for the lowpass filter.I also substituded the LM78/79 regulators with the lower noise MC variants.Nothing exotic but definately a few notches above the stock parts.
The DAC circuit itself is as simple as it gets.There is no USB input or sample rate convertor ,instead input is via SPDIF into a Cirrus CS8416 DIR followed by an AKM4396 dac chip then to the low pass filter/output buffer.AKM is one of the biggest makers of DAC chips but these are mostly found in higher end soundcards.On paper atleast the AKM4396 is an excellent DAC and appears to be the equal of the dual differential 24/192k offerings from Cirrus and Burr Brown.
However it is my opinion that it is the analog section that can have an even greater influence on sound quality than the specific data converter used.The opamp included with the kit is the archaic 5532.Not the worst sounding device around but far from the last word in resolution.I find it on the soft slightly dark side sonically.I will be replacing it with a pair of discrete class A opamp's similar those marketed by Burson.
Also in an atempt to not adversly affect the signal - noise performance and preserve all those 24bit's of resolution I will be placing the little toroidal transformer in it's own separate chassis to prevent the possibility of any 60hz hum being coupled into the output.
I found a Hammond case with ideal dimensions for the PC board.
Post edited by FTGV on
  • steveinaz
    steveinaz Posts: 19,545
    edited August 2011
    Cool!!!
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    steveinaz wrote: »
    Cool!!!
    Thanks to you I recieved atleast one reply.:smile:I guess this speaks to my popularity in these parts as being that of p*nis at a **** slumber party.HeHe
    Anyway here is the finished product.It worked flawlessly at first power up without any extraneous noises or smoke.:biggrin: I have been doing some listening with an LM4562 opamp installed since the discrete units are not ready to go yet. First impressions are extemely positive, sounding open and airy and detailed but with a slightly lightweight bottom end.I expect things to change(hopfully for the better)when I get the other opamps installed.
    As for futher mods I plan to install a pulse transformer to provide isolation from the PC and maybe some further power supply tweaks.
    The retina damaging ultra intense blue LED's used for power and sample rate indication will be toned down or changed to green and red respectively.
    All said and done I think this is a great little board with an excellent lay out and very conducive to modifications. I'm very pleased with the results considering my total outlay of approx.$70 ($40 kit ebay,$30 digi key)not including parts I already had on hand.I can highly recommend the kit for someone looking to try an inexpensive DIY unit.
    I can provide a link to the ebay seller if anyone is interested.
    p1.JPG 314.4K
    p2.JPG 267.5K
    p3.JPG 229.2K
    Ip4.JPG 252.4K
  • Poee7R
    Poee7R Posts: 906
    edited August 2011
    Looks good man, and I agree with the blue led's, toss em for sure.
    I was really excited while reading, until I came to the part about no usb input. Im looking for a diy dac myself, but Im interested in building one for a pc rig, so I need USB or Ill have to add another component.
    So I have two questions, can a usb input be added without much of a problem? (not sure on the premise of adding a usb input and wether or not it is even possible without it being better to go with a different unit)
    And second question... Ive looked at all the pics a few times now, where do you stick the tube? :biggrin:
    Dave
    Once again we meet at last.
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    Poee7R wrote: »
    There is a very similar kit(see link) that adds a USB input, however since it is of non async. variety so that input will be limited to 16bit/48k.
    Otherwise if you desire hi res capability via USB you'll need an external solution.The other main difference that I can see between this and the board I purchased is the DAC chip , a Cirrus CS4398 vs the AK4396,though they are similarily spec'd.
    http://www.ebay.ca/itm/CS8416-CS4398-192Khz-24Bit-DAC-USB-Coaxial-Assembled-/260814783037?pt=LH_DefaultDomain_0&hash=item3cb9c5c23d
    It so happens that I do have a suggestion as to where you can stick that tube.:eek::tongue:
    heiney9 Posts: 25,403
    edited August 2011
    Fred, very cool. Can you build me one?
    P.s. I don't surf the DIY Mods and Tweaks forum on a regular basis otherwise I would have seen it sooner.
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    heiney9 wrote: »
    Sure if you send me the parts I can assemble it.
  • agfrost
    agfrost Posts: 2,461
    edited August 2011
    Looks nice, Fred. Please keep updating as time goes on/as you continue to massage it.
    Jay
    Jay
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2011
    Great job GV, thanks for sharing with us.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    SCompRacer Posts: 9,084
    edited August 2011
    Nice job Fred! One area I am not finished with yet is DAC's. Oh, and a TT plinth project.
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    Thanks ag,TK and Rich.
    I have the discete opamps installed.Since two are required I needed to adapt the mini PC boards on to an 8 pin DIP header so that it would fit into the standard IC socket. Initial impressions are of greater weight in the bottom end with a more refined top end but still with a somewhat uptilted response in comparison to my regular DAC.
    DOA.JPG 288.4K
  • Face
    Face Posts: 14,340
    edited August 2011
    Nice job Fred! But where are the tubes? :biggrin:
    Is it direct coupled?
  • FTGV
    FTGV Posts: 3,650
    edited August 2011
    Face wrote: »
    Can't get em to fit in the dang IC socket.:frown:
    Yes.
  • FTGV
    FTGV Posts: 3,650
    edited September 2011
    Adding a pulse transformer for the SPDIF input is last tweek planned for this unit.Transformer coupling provides galvanic isolation which is particularly important when the DAC is used with a PC's coaxial digital output.It will effectively isolate the DAC from any noise artifacts (like from the computer's switching supply) and eliminate the possibility of a ground loop.
    The transformer is a Newava S22083 http://www.newava.com/pdf/S22083.pdf and sourced from Digi key for <$10.
    I recommmend it as a possible upgrade for any DAC that does'nt have one on it's coaxial input (such as the original MF V-DAC).
    After installation I believe I'm hearing a smoother and more detailed high end with a better sense of space.
    Overall the more I listen to this little DAC the more impressed I am with it's ability to reveal the little details and nuances from well recorded acoustic guitar tunes from the likes of Al DiMeola,Justin King,Alex Degrassi,Clapton.Etc.It digs deep but IMO without becoming unaturally hyper detailed.
    Obviously manufacturer hyperbole but AKM refer to the 4396 as the "miracle dac" because it is claimed that it's hi frequency noise levels are similar to a good R2R DAC and substantially lower than competitors delta -sigma chips .
    How much this contributes to the excellent resolution I'm hearing I'm not sure .
    TF1.JPG 358.3K
    TF2.JPG 213.5K
  • drselect
    drselect Posts: 664
    Nice looking work Fred.
    Might have missed it but where is the link for were you got the initial kit from?
    Also you mention adding descrete opamps could you please provide a little more info about them?
    jinno1, nice try. Reported.
    Awesome work Fred! I too would like to know more about your discrete opamps. I'm a believer in them. I'd also like you to give me a working with small coax class...nice job on the braid grounds! No way you cut it; you, what's the right word, un-braid or de-braid it, right? I have an air bearing tonearm to rewire using some 1/8" coax. One end goes to a small PCB in a tight place. Maybe I'll send it to you!:lol:
  • george daniel
    george daniel Posts: 12,096
    edited October 2011
    Very nice work Fred--with your skills and talent,,I'm sure this was childs play to you.Me,,,I'm a "paint by the numbers" guy. :biggrin:
  • FTGV
    FTGV Posts: 3,650
    edited October 2011
    drselect wrote: »
    Thanks,variations of this kit are available from a number of vendors here is the link to the one I purchased from.http://www.ebay.ca/itm/NEW-Hi-end-DAC-24-BIT-192K-HZ-AK4396-sc-/200613201099?pt=LH_DefaultDomain_0&hash=item2eb57a84cb
    Dont let the source and price fool you,the quality of the PC board is very good and the DIR and DAC IC's are the real deal not counterfits.
    I'm now working on another one ,the one I linked to in post#5 http://www.ebay.ca/itm/120768083816?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
    It is near Identical with the exception of adding a USB input(16bit/48k adaptive mode)and swapping the AKM4396 with a Cirrus CS4398.For this version I will be using a completely separate power supply for the digital and analog sections,(each with their own AMVECO mini toroid transformer)and high performance shunt regulators for the analog.
    The pretty black and gold PC boards are the shunt reg's.
  • FTGV
    FTGV Posts: 3,650
    edited October 2011
    SCompRacer wrote: »
    After stripping off about a 1/2" of the outer insulation I just gathered the shield to one side and twisted it into a braid for easy soldering.The opamp's were pulled from another otherwise defective piece of equipment,they are dual differential Class A using bipolar transistors vs the Burson's which use fets.
    Thanks for the kind words Mike and George.
  • praedet
    praedet Posts: 314
    edited October 2011
    I actually need to try that transformer technique on my DAC. What is the second blue part with the transformer?
    HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
    Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
    2 APC H-15s and a Panamax 5400 for good measure ;)
    Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
  • FTGV
    FTGV Posts: 3,650
    edited October 2011
    praedet wrote: »
    Thats a 220nf poly cap to block any miniscule DC that might find it's way on to the data line.
    Here is a link to the Digi-key part# for both the transformer and cap.
    http://search.digikey.com/scripts/DkSearch/dksus.dll?lang=en&site=CA&KeyWords=470-1003-ND&x=21&y=14
    http://search.digikey.com/scripts/DkSearch/dksus.dll?vendor=0&keywords=495-1106-ND
  • Face
    Face Posts: 14,340
    edited October 2011
    I refuse to drink the Kool Aid
  • FTGV
    FTGV Posts: 3,650
    edited October 2011
    Face wrote: »
    As always nice to here from you and thanks for the kind words.:wink:
  • FTGV
    FTGV Posts: 3,650
    edited February 2012
    To add some versatility to the DAC I purchased this little USB transceiver/DAC board which will allow me to also use my lap top.The board is based on the Burr Brown PCM2704 which is a USB reciever,SPDIF transmitter and basic 16 bit stereo Delta Sigma dac all on one IC chip.USB is limited to 16/48k adaptive mode operation and the board includes a pulse transformer on the SPDIF output. While certainly outclassed by newer USB chips it is completely adeqate for use with a lap top for streaming internet radio or itunes etc.It also does a credible job with flac files via J River Media Center. (operating in WASAPI mode).I installed the PC board in a small plastic case which makes for a very compact and portable unit.I used a 75 ohm BNC for SPDIF output and since the PCM2704 also has a stereo analog voltage output I included a pair of RCA connectors thus making it a complete self contained USB DAC.While sound quality is compromised using the on board DAC it is very convenient for times when my daugther wants to hook her lap top into a rig.
    My Keces DA-151 uses the PCM2702 (very similar) for USB and the designer basically said the same thing. Not state of the art but when implemented correctly the strenghts can be exploited and the weaknesses minimized and so far what I'm hearing out of the Keces is really, really good. Careful attention to the power supply and a seperate clock helps to improve performance a lot.
    Three words describe the Keces; effortless, cohesive, dead quiet.
    Enjoy Fred, nice work as usual.
  • Face
    Face Posts: 14,340
    Great job Fred.
  • FTGV
    FTGV Posts: 3,650
    heiney9 wrote: »
    My Keces DA-151 uses the PCM2702 (very similar) for USB ....
    Yeah Brock from what I gather the two chips differ only in that the 2704 has an SPDIF (and I2S) output so can function as just a USB -SPDIF convertor to feed a separate DAC ,with the 2702 you must use the on chip DAC.I could have put it in a larger case and used a nice regulated power supply but with this unit convenience and portability trump ultimate sound quality.
    Good to see you have found a DAC you like for your office rig within your budget.
    As usual, high marks Fred! Fox crystal....hmmmm, I see a trend here.:cheesygrin:
    I see you added a test port. I have them same fittings on my oscilloscope.
    :cheesygrin: I know, I know, BNC, a true 75 Ohm connector.
  • FTGV
    FTGV Posts: 3,650
    SCompRacer wrote: »
    Thats what came already installed.Not sure of the freq.stability spec.
  • FTGV
    FTGV Posts: 3,650
    edited February 2013
    I built up another one of these simple little DAC's so that I can do a comparison of two different D-A chips to see if I could discern any audible differences.Of course the quality of the power supplies and the analog output stages play a large roll but I'm curious to see if I can hear any differences between equally spec'd chips from two different companies.Namely the Cirrus CS4398 and AKM AK4396 both are 24bit/192 k Delta-Sigma differential voltage output devices.Other than the addition of a 16/48k non async USB input on the Cirrus board the two are near identical thus making it an apples to apples comparison.Both very similar PC board layouts,the same power supply scheme,and use the same Cirrus CS8416 digital input reciever.
    As with the original AKM board I used Panasonic FC series electrolytics for local decoupling ,and Panny stacked film's for supply bypassing.
    Aswell a BNC connector is used to assure proper 75 ohm termination impedance and a pulse transformer provides galvanic isolation from my PC's soundcard.The main filter caps in the second board are UCC's vs Nchicon's in the first.
    As the pics show I used another though slightly larger version of the cute little Hammond cases.After I'm finished with the comparo I will use the extra chassis space to beef up the main filter capacitance with the addition of an auxillary PC board with 4x 3900uf.
    D1.JPG 296.1K
    D2.JPG 311.9K
