Possible SRS 3.1
jimbo1421
Hello,
Tomorrow I go to look at a pair of what may be SRS 3.1s. The seller didn't know the model. Asking price $300. Since they are in a storage locker with maybe no power I probably will not be able to audition them, although I will bring an amp and my MacBook Pro just in case I can run some iTunes. I can do the press test and check for frozen drivers. I have the SDA Quick Test file but it doesn't list voltmeter values for the SRS 3.1. Does anyone know what they are?
I worry about how they have been stored for the last six months. I imagine it must be well over 100 degrees in the storage locker. All summer. Can this kind of heat cause damage to any of the drivers or crossover?
Is there anything else I should look for? Is this a reasonable price?
Finally, I already have a pair of SDA-1bs to which I have not yet done much work. I have Dynamatted and Mortited, but that's it. My intention has been to replace the SL-2000 tweeter and rebuild the crossover (probably $400). But now I wonder if I can avoid that expense by buying the 3.1 pair. Would the SL-3000 tweeters be due for replacement? Would the crossover rebuild be more costly for the SRS 3.1?
I sure would appreciate any guidance you can give.
Thanks,
Jim
Thanks,
Jim
5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
Surround: Monitor 10B
PSW10 subwoofer
Onkyo PR-SC886P Pre/Pro
NAD T955 5 channel power amplifier
Technics SL-1710 MK2 turntable
Audio-Technica AT14Sa cartridge
Parasound P3 pre-amp
Oppo BDP-103 Blu-Ray
2014 MacBook Pro 2.8 GHz
2.0 Office System:
Monitor 10A (Peerless)
Outlaw 1050 receiver
Parasound HCA-1000A power amp
MacPro
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro
Post edited by jimbo1421 on
The price is more than reasonable, and the closer to perfect they are the better it gets. I can only guess that the temps inside that locker have been brutal, and maybe exceeding 140 degrees on the hottest days. I too would be concerned about how the heat affected them, and would consider offering less if you find them to be needing a lot of work. Sorry I can't be of any more help than this, but congrats on the find and I wish you the best.
Remember, we ned pics or it never happened.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
Polk tests all their drivers, etc. for temperature extremes. No worries there.Would the SL-3000 tweeters be due for replacement?
Hell yeah, the RD0198-1's are much better.Political Correctness'.........defined
President of Club Polk -
I found the RD-0198 tweeters to be a stunning upgrade over the SL3000's. I expected a modest, subtle improvement - but what I got was a nice surprise!"Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer
I believe I remember an informal "opinion poll" on here about the "best" SDA's and if memory serves the general consensus was SDA 2.3TL, 1C's, and 3.1's (close on the last two). It may have been a bang for the buck thing rather than simply a best thing. Regardless, $300 sounds like an amazingly good price even if a little work was needed.Sony 60'' SXRD 1080p
Amp = Carver AV-705THX 5-Channel
Processor = NAD T747
Panasonic BD35 Blu-Ray
Main = SDA-1C Studio with RD0s, spikes, XO rebuild, rings, I/C upgrade
Center=Polk CS10, Surround = Athena Dipoles, Sub= Boston 12HO
Music/Video Streaming = Netgear NEO550
TT = Audio Technica -
Thanks, that's good to know.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
wow, what a deal (if they're in good shape). I've got a little more than that in my 2A's. please let us know how this turns out!Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
Well, these turned out to be SRS 2.3 with SL-2000 tweeters. Here is the link:
http://albuquerque.craigslist.org/fud/2523124867.html
They are way too big for my space so I passed and clued the seller in to their real value. It seemed that she really needed to get a fair price for them.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Holy smokes NOW that a serious steel of a deal. 2.3's are a crown jewel.engtaz
Jim
I think the heat may have affected your brain just a touch. The 2.3's for 300 bucks?? walking on those is like walking away from an SL500 for $20.00.:eek:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »I think the heat may have affected your brain just a touch. The 2.3's for 300 bucks?? walking on those is like walking away from an SL500 for $20.00.:eek:
I know! Even though they weren't TL!! I would have jumped all over them. Too bad I am not in NM....
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
The seller was an unemployed young woman who needed to get a fair price for them far more than I needed a giant pair of speakers. This was my good deed for the year.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Good on you, Jim. A bargain taking advantage of the needy isn't such a great bargain at all.
JayJay
Jay
Before you all start singing praises to my name, keep in mind that if I really wanted a giant pair of Polks I would have bought them on the spot for $300. All I really did was forego the opportunity to flip them for $700.
Jim5.1 System:
TCL R613 55" 4K
Front: SRS-3.1TL
Center: CS400i
PSW10 subwoofer
2.0 Office System:
MacPro -
Now the next person in need of a cheap pair of SDA's is going to have to pay 400.00 more...
Thanks.
But for now, her price is still the same it seems. The one's lying on its side. I think they rescued from more than getting a fair price for her.Most people just listen to music and watch movies. I EXPERIENCE them.
tony millard wrote: »Now the next person in need of a cheap pair of SDA's is going to have to pay 400.00 more...
Thanks.
^^^this.
they appear to need a bunch of work to get them right, and by the time that's done, they won't be as much of a bargainThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'm not sure the speaker is laying on it's side. It looks like the picture is 90 degrees off.
Mikepolkaudio
Currently Own:
RTA-11T Light Oak, Aug/2011 to present
SDA-CRS+ Aug/2011 to present
RTA-11T Black, Dec/2013 to present
Previously Owned:
SDA-SRS 2.3 May/1990 to June/1991
SRS 1.2TL June/1991 to May/1995
SDA-1C Aug/2005 to Dec/2011
SRS 1.2TL Sept/2009 to Sept/2015
