Fix Denon 825R vs. buy new
egsba
egsba Posts: 2
edited August 2011 in 2 Channel Audio
Hi,
I've got a Denon DRA 825R from the 1980s. I have some buzzing sounds/audio drop off that occur often. Any thoughts if it's worth repairing vs. buying a new amplifier? also, if repairing, anyone use gold crown in Carson, CA vs. the Panurgy OEM for their repairs?
thanks!
Post edited by egsba on
  • skrol
    skrol Posts: 3,462
    edited August 2011
    There was a guy here with the same receiver that was sending it for repairs. http://www.polkaudio.com/forums/showthread.php?t=121782 Might talk to him to see where he sent his and how it turned out.
    I have had my DRA-825R since 1991. I had to fix several bad solder joints but it works perfect. It is a shame that it is collecting dust since I picked up an 835R.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • mantis
    mantis Posts: 17,559
    edited August 2011
    Depends on the cost of the repair. Getting a new receiver will yield new features and up to date technology . But if none of that is attractive to you and the Denon does everything you want , then I would repair it.
    Dan
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2011
    Get rid of the old POS. Help the economy, and yourself, by buying new gear. After 30 years it is time for an upgrade.
  • skrol
    skrol Posts: 3,462
    edited August 2011
    Ouch!
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • egsba
    egsba Posts: 2
    edited August 2011
    I was given a quote on the phone for $75 plus labor from the Denon super service center. I'm going to help the economy with my new floor speakers that I'll get with the repaired receiver!
