Help putting banana plugs into speakers
hookem12
hookem12 Posts: 22
I was wondering if someone could clear things up on how to put in my banana plug speaker cables. I have the polk rti a3 and all I can gather from the manual is to:
Carefully pry out the binding post plugs
to expose banana plug holes.
Do I unscrew the entire cap and does it matter if I use the top or bottom row?
Post edited by hookem12 on
  • Big Dawg
    Big Dawg Posts: 2,005
    edited August 2011
    Do NOT unscrew - would make too fragile.
    As long as you have the jumper (brass piece) in place, it doesn't matter.
  • george daniel
    george daniel Posts: 12,096
    edited August 2011
    remove the "nut" and the little inserts will come out,,pop those nanners in place--I would use the lower posts,,just be sure the jumpers(if applicable) are in place,,as long as you have jumpers in place,it does not matter.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited August 2011
    I just unscrewed the caps on my monitor 70s, the small plug inside came right out.You shouldn't have to pry, I use the top posts but don't think it matters witch ones you use.Maby some of the long time members can give you more info.I'm just telling you how I did mine. Good luck Dan
  • Oldfatdogs
    edited August 2011
    George, is there any particular reason you use the bottom posts?
  • mantis
    mantis Posts: 17,324
    edited August 2011
    I should do a instructional video on this subject. It's the new thing how people have no idea how to use banana plugs. It's cool and all I'll at least post some picks here for you to see how they look when properly inserted.
    Dan
  • mantis
    edited August 2011
    http://www.aperionaudio.com/AperionU/banana-plugs.aspx
    Please watch this video at least 10 times over so you have a deep understanding.
    Dan
  • mantis
    edited August 2011
    http://www.youtube.com/watch?v=ZbymrIeOhQA&feature=related
    Here is another video for your viewing pleasure and learning curve.
    Dan
  • mantis
    edited August 2011
    Dan
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited August 2011
    I'm so proud, because somehow I figured all of this out on my own without ever having to read instructions or watch a movie!!!! :redface::biggrin:
    I don't know how I ever did it?? :confused:
  • decal
    decal Posts: 3,205
    edited August 2011
    mdaudioguy wrote: »
    Me,too!!!!!!!
  • mantis
    edited August 2011
    Some people just are not mechanically inclined , and thats ok.
    Dan
    Tony M Posts: 11,589
    edited August 2011
    mantis wrote: »
    That's it in a nut shell.
    I was mech. inclined but my brother wasn't. He could remember every joke he ever heard, I can't. It's just the cards we're dealt with.:wink:
    Then there's common sense.....that's not so common anymore..:eek:
  • mdaudioguy
    edited August 2011
    mantis wrote: »
    Yeah, I kinda get that, but how much inclination does it take? It just seems so simple, and yet, the next thing you know, some dude's snapping off his binding post. I mean, I could do something dumb like that, too...
    But the questions that come up on here... Perhaps someone at Polk should spend a little time and add some info to the manuals. Maybe some better diagrams and explanations of the various connection options. The first thing they should include is something about the jumpers - their purpose, the fact that if they're in place it really doesn't matter whether you connect to the top or bottom, etc... You wouldn't need more than a page to clear up a lot of the confusion that's caused, such as it seems.
  • Mon40CSMM10
    Mon40CSMM10 Posts: 161
    edited August 2011
    To add to the confusion, sometimes the binding post can be removed all the way and other times it can only be loosened to a maximum.
    Polk Monitor 40 can be removed all the way, then it's just a question of inverting the binding post and the small plug pops out without any problem.
    Polk CSM cannot be removed all the way, for some reason--the plug can be loosened only to a certain point. Need to use a needle nose pliers (also called mini long nose pliers in some tool kits) to pry out the plug when the binding post is in the fully tightened position.
    As for the banana plugs themselves, it's usually just a matter of twisting the speaker wire and then **** on the banana plug; however, check the direction. I have some where the protective cover shows a COUNTERCLOCKWISE direction, therefore, the speaker wire has to be twisted counterclockwise, then the banana plug is tightened over the twisted wire in a counter clockwise direction.
    Assuming all that is known, the procedure becomes:
    1. Remove plugs from the binding posts.
    2. Reinstall binding posts by tightening all the way.
    3. Twist the speaker wire strands in the direction the banana plug tightening direction for both the positive and negative speaker wires.
    4. Slide the protective cover (if included) on the wire past the speaker wire strands.
    5.Tighten one banana plug for the positive side, another one for the negative side.
    6. Slide the protective cover (if included) over the non-connecting side of the banana plug.
    7. Insert each banana plug into the hole in the binding post.
    Repeat for each speaker to be connected by the banana plug method.
  • To add to the confusion, sometimes the binding post can be removed all the way and other times it can only be loosened to a maximum.
    I couldn't find an answer to banana plugs- why? Because my binding posts wouldn't come all the way out on our signature elite gear... so thank you for spelling it out for someone who is very mechanically inclined but isn't going to go pulling and prying on $1,500 worth of wedding presents!
    Thank you Mon40CSMM10!!
